scott87 Posted January 9, 2013 Share Posted January 9, 2013 Just been out having some pictures taken of the Supra and driving round have noticed that im getting a knocking or clunking noise coming from the rear driverside under braking. What would cause the brake/caliper to do this? Ive got new disks and pads all round. Link to comment Share on other sites More sharing options...
safcdixon Posted January 9, 2013 Share Posted January 9, 2013 maybe you have a loose bolt from when they were changed, or could be something like a shocker absorber knocking when its under load Link to comment Share on other sites More sharing options...
Dnk Posted January 9, 2013 Share Posted January 9, 2013 Loose wheel, loose caliper bolts is the first things i'd check and asap Link to comment Share on other sites More sharing options...
scott87 Posted January 9, 2013 Author Share Posted January 9, 2013 Loose wheel, loose caliper bolts is the first things i'd check and asap Ill check these first tomorrow. I did do everything up nice and tight but will check nothing has come loose. Link to comment Share on other sites More sharing options...
mihai Posted January 9, 2013 Share Posted January 9, 2013 Squeqy brakes ?? Is normally if they are ceramic and cold.... Link to comment Share on other sites More sharing options...
Dnk Posted January 9, 2013 Share Posted January 9, 2013 Squeqy brakes ?? Is normally if they are ceramic and cold.... ? Link to comment Share on other sites More sharing options...
scott87 Posted January 9, 2013 Author Share Posted January 9, 2013 Squeqy brakes ?? Is normally if they are ceramic and cold.... Def a knock not a squeak..... Link to comment Share on other sites More sharing options...
supra900bhp Posted January 9, 2013 Share Posted January 9, 2013 Ill check these first tomorrow. I did do everything up nice and tight but will check nothing has come loose. could be play in the new pads?? I had prob in the evo 6 pins had rubbed alittle and were letting pads move just 1mm but clonked like a bitch done my headin as checked everything 2-3 times new pins and was clonk was gone. carn't remember if they have locating screw?? if so did you refit?? if not disc may move on hub for a clonk? err only other thing is check hand brake cable shoes may have moved just abit to misaline also is it all moving free?? hope it easy fix mate Link to comment Share on other sites More sharing options...
scott87 Posted January 9, 2013 Author Share Posted January 9, 2013 could be play in the new pads?? I had prob in the evo 6 pins had rubbed alittle and were letting pads move just 1mm but clonked like a bitch done my headin as checked everything 2-3 times new pins and was clonk was gone. carn't remember if they have locating screw?? if so did you refit?? if not disc may move on hub for a clonk? err only other thing is check hand brake cable shoes may have moved just abit to misaline also is it all moving free?? hope it easy fix mate Yer thats what is was thinking perhaps the securing pin thing has popped out or is a bit worn. I will check this too It doesn;t sound like something broken it is more a something is moving sound... Link to comment Share on other sites More sharing options...
Guigsy Posted January 9, 2013 Share Posted January 9, 2013 I got a knocking noise after a top speed run at thunder road. Turned out one of the calliper securing bolts had fallen out and the calliper was being pushed outwards and hitting the wheel. It knocked off all the wheel weights. Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 9, 2013 Share Posted January 9, 2013 I got a knocking noise after a top speed run at thunder road. Turned out one of the calliper securing bolts had fallen out and the calliper was being pushed outwards and hitting the wheel. It knocked off all the wheel weights. Nice!! would have bedded in after a while, so no drama Link to comment Share on other sites More sharing options...
