tire size help
l.chris97
Just orderd my new rims today .. they are custom rims so i dont know the offsets but they are 18x9.5 front and 18x 11 rear and are going on a standard bodied prefacelift (no rolled arches either)...just a question on the tyre size i need..i have seen the quides on sizes on here but am i jumping the gun by trying to order tires before the wheels come as i dont know the offset so that makes it harder to judge the space available for the tyres...
Also can people leave a few susgestions on tires they would recommend..i want a good all round preforming tire.
Thanks guys.
You're buying wheels, not knowing the offsets?
:Popcorn:
However.....off the top of my head....275-295/35/18
The company making them has done loads of supras so he uses his custom offsets for all standard supras...i have asked him but hes on holidays at the min so hasnt got back to me yet with the offsets he is using.
If they will fit nicely (which if your man has done a few sets :think: should do) then the sizes I posted originally are what you should look for I think. (Using the maths in my head)
Cheers mate....i hope they do fit nicely....there costing enough....any recommended tires...forgot to mention the cars only bpu at the min
255 is for a 10" wheel ;)
Oh the size I put up is for the rears only.
So front would be (between) 235-255/40/18
Rears would be (between) 275-295/35/18
Also just realised, i think you will struggle to get full lock without rubbing on the fronts with stock arches on 9.5 wheels.
Edited by listy (see edit history)
I've kinda asked all them questions...he was trying to get me to go with a 10 front and 11 rear...and promised a perfect fit and that he never had any issues with those sizes on supras before....but i pulled it back to 9.5 because i didnt feel the need for a 10 on the front and if he though a 10 was ok a 9.5 would give me that little bit more scope..
http://www.etyres.co.uk/tyre-size-calculator.htm
http://www.1010tires.com/wheeloffsetcalculator.asp
Rim width---Min tyre width----Ideal tyre width-------Max tyre width
7.0 inches-----195 mm--------205 or 215 mm-----------225 mm
7.5 inches-----205 mm--------215 or 225 mm-----------235 mm
8.0 inches-----215 mm--------225 or 235 mm-----------245 mm
8.5 inches-----225 mm--------235 or 245 mm-----------255 mm
9,0 inches-----235 mm--------245 or 255 mm-----------265 mm
9.5 inches-----245 mm--------255 or 265 mm-----------275 mm
10.0 inches----255 mm--------265 or 275 mm-----------285 mm
10.5 inches----265 mm--------275 or 285 mm-----------295 mm
11.0 inches----275 mm--------285 or 295 mm-----------305 mm
11.5 inches----285 mm--------295 or 305 mm-----------315 mm
12.0 inches----295 mm--------305 or 315 mm-----------325 mm
12.5 inches----305 mm--------315 or 325 mm-----------335 mm
I'd have asked for the tyres to be fitted to the wheels before delivery.
I still can ask but since there in the states the choice of tyres they show on there website isnt great..and the extra carraige for 4 tyres is a bit excessive..i will email him and ask what he will do as a package deal.
cheers mate
No problem.
You don't need to spend all your budget to get decent tyres on your car, i am
trying the Avon ZZ3's on mine and i'm quite happy with how their performing and
their pretty cheap compared to most, even cheaper than Falkens :blink:
