Dan_Q Posted January 7, 2013 Share Posted January 7, 2013 Hi All, I've had a search but could have missed something. Does anyone know of any re-useable type rear ARB droplinks that are available for the MK4? IE ones that have through bolts and nuts on polybushes sort of thing, rather than the easily damaged standard allen / hex and nut type. Thanks in advance Dan. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 7, 2013 Share Posted January 7, 2013 (edited) Demon Tweeks Search drop links on http://www.demon-tweeks.co.uk Whiteline universal are £104 You could easily make your own but the spherical joints for something decent are going to be around £20 each Edited January 7, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 8, 2013 Share Posted January 8, 2013 I can make these, but I would want to use good quality rod ends, which means they'll be a LOT dearer than stock ones, but will be adjustable for preload removal. I will tell you with certainty, ones made with cheap rod ends WILL knock sooner than stock links. Good rod ends are EXPENSIVE. I have made them for loads of cars. I think dnk's price for good rod ends is optimistic. Quote Link to comment Share on other sites More sharing options...
Dnk Posted January 8, 2013 Share Posted January 8, 2013 (edited) Agreed their cheap but if you go to teflon coated all singing and dancing your probably into £50 each if not more. For road use i personally wouldn't bother and fit o/e drop links which will probably last longer than even the much more expensive rod ends. Edited January 8, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted January 9, 2013 Author Share Posted January 9, 2013 Thanks very much for the replies guys, i hadnt seen the whiteline universal ones- look good, will look into it Chris, what sort of money are we talking? i'm on a tight budget but also prefer to do a job once if you know what I mean. Oh and thanks for the parts you sent me before xmas all arrived OK, its just rare i use my out of work emails thats all and I forgot until now Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted January 9, 2013 Share Posted January 9, 2013 You are far better off with new stock links, the Whiteline stuff is very low end, they'll use cheap rod ends. As one offs about £130 per link with pretty decent rod ends, from me, on car adjustable for length (LH and RH joints). Quote Link to comment Share on other sites More sharing options...
Dan_Q Posted January 10, 2013 Author Share Posted January 10, 2013 Chris- brilliant information as usual, I'll use stock links but get another pair "in stock" incase i break one on adjustment. thanks very much people great help yet again Quote Link to comment Share on other sites More sharing options...
