Who has (or is doing) an NA-T on the forum?
d-_-b
  • Replies 664
Posted Images
Ignore that, thought you wanted the part number for the dizzy cap, that's what I get for speed reading dumb dumb :twak
Haha, no probs dude, if you could still check & confirm that would be good to have a second clarification to make sure ive put up the right number in the discussion thread in the NA-T group thread. :thumbs:
b;3579514']Haha' date=' no probs dude, if you could still check & confirm that would be good to have a second clarification to make sure ive put up the right number in the discussion thread in the NA-T group thread. :thumbs:[/quote']
Yep that is the correct part number.
Walbro fuel pump number: GSS342
http://www.mkivsupra.net/vbb/showthread.php?45647-How-to-change-a-Supra-fuel-pump
Also this might help with wiring gauges to the clock loom, I have just installed 2 aem gauges and 2 depo gauges, they work but I'm having trouble with the afr gauge, it powers up for a short period of time then shuts off, does anyone know if its ok to power 4 gauges from the clock loom??
Red = Perm +v
White/Black = Gnd 0v
Green/Orange = Light Power
Blue/Red = Switched Power
Red = Perm +v
Is your afr running its own lambda O2 sensor? If so it needs a good supply as the sensor is heated
b;3579517']Ahhh,
So is it just the stock #2 HT lead for the Supra then dude?
- So you have effectivly, 2 x #2 HT leads in the 6.
(sorry if sounds a obvious question :lol:)
Yeah that's correct, but Ive since changed to 8.5mm ht leads. I rang magnecor direct and got them to make me aset up. #2, #2, #3, #4, #5, #6. :)
But they put #1 on one of the longer #2 leads so I don't get confused when taking them off and on, I didn't ask them too but they must of known how dum I am lol :D
Edited by FOSTA (see edit history)
If anyone is after a GE lump to build on I have a complete engine here complete with intake manifold, throttle body, distributor, Leads, recently changed cam belt, cam covers
£100
Also have a standard Toyota W58 clutch and Manual ECU up for grabs!
It will do once I fit it.. I'm not actually running na-t yet but i got excited and couldn't wait to install my gauges, so I just have the plug For the 02 sensor taped up out the way. I'm now wondering if its because the sensors not plugged in?? Il check this tomorrow!
£100
Must resist!!! I'm so tempted but funds are tight at the minute, out of interest How's the rear crank seal? Mines leaking oil!
for guys running 5-600 hp. Are you using an uprated oil cooler in your setups ? and secondly are you using a seperate boost controller or is the piggy back able to regulate boost? thanks in advance
I would Highly expect so.. and personally i would get a boost controller just for ease of use to be honest! (just my oppinion)
Yep I have a AEM TRU boost and I will be adding a oil cooler in the front bumper :)
