Who has (or is doing) an NA-T on the forum?
d-_-b
  • Replies 664
Posted Images
b;3615562']For any NA-T guys considering going the R154 Getrag gearbox route with their NA-T conversion;
Bellhousing to allow you to use a Supra mkiii R154 box with the 2J engine. Just extending the shifter req then.
> R154 2JZ bellhousing for sale
More R154 parts fella's; used Stage 4 Competition Clutch for a R154:
> R154 Stage 4 Competition Clutch for sale
Finished checking over the wiring for the E-manage Blue against the spreadsheet diagram that was provided by IanC.
Will pop up a post about this when i get 5 mins. :thumbs:
  • 2 weeks later...
For anyone going to be running a Greddy Emanage Blue - ECU Patch harness with Greddy Blue main & injector harness wired in (as mentioned in few posts above) up for sale in the For Sale section.
Plug & Play anyone! :)
i still cant find any information on jumper 21? im going to test the ecu today, hopefully it powers up so i can finish off the wiring.
what i would like to know is when i connect the ecu to the laptop does it auto update or do i need to go online and find a specific software update and install it while its plugged into the car? and can i just use the basic wiring ie power, map, rpm and tps to update?
  • 2 weeks later...
not much, the other half decided my time was better spent installing a new bathroom so im running behind. Might need to take some more time off work to get it done!! i would also like to know about jumper 21 as above.
My build started half hour ago.. Then it started raining, I'm not blessed with a warm garage to work in so I'm stuck with working in the grove with nagging kids asking me millions of questions!
I use my car daily so i did odd jobs on the weekend to keep it mobile, so far fuel pump, EMU wiring, gauges, fmic and piping has all been done, now I'm at the stage of no return.. Drilling the sump.
Jumper 21 I'm also still unsure about? And weather the settings will be the same as posted in club na-t
Just a heads up, I'm on the lookout for an Emanage Ultimate or similar piggy back set up should anyone have anything or know of anything.
Good luck too those who've builds have started, I'm just waiting on a run around so I can get mine off the road and begin! Most the parts are here now :) This Sundays weather is forecast to be good so ideal for a good days progress!
What's up with Jumper 21, are you looking for wiring diagrams buddy? I'm confused on your problem. Sorry Im not being much help.
The laptop needs the emanage update (in my case) if it doesn't connect when the engine in running.
No mate wirings all done, when I came to set the jumper settings the EMU i bought (b series) doesn't have a jp21 so was just wondering if all the other settings would still be the same as what FOSTA posted?
What is jp21 for?
Jp - 1 - open
jp - 2 - open
jp - 3 - open
jp - 4 - open
jp - 5 - open
jp - 6 - open
jp - 7 - 1-2
jp - 8 - 1-2
jp - 9 - open
jp - 10 - 1-2
jp - 11 - open
jp - 12 - open
jp - 13 - open
jp - 14 - open
jp - 15 - 1-2
jp - 16 - open
jp - 17 - 1-2
jp - 18 - open
jp - 19 - 1-2
jp - 20 - 1-2
jp - 21 - 1-2
Oh I see you just want to know what's it's purpose.
http://www.toyotagtturbo.com/forums/showthread.php?72782-E-manage-ultimate-warm-start-issue.
That thread has some information on some starlets that have a warm start issue, one guy reckons that some EMU have 21 jumpers, which means that some dont and it's not uncommon.
I would not panic too much about it, see how it idles and investigate further if the idle has any problems.
Here's information about what all the others are, for some reason 21 isn't even on there so I wouldn't worry about the other settings mate
http://forum.miata.net/vb/showthread.php?t=158911
  • 2 weeks later...
Hello to all,
Please add me as well,
Supra NA-T Aerotop Under Construction!
Looking for R154 Conversion
Turbo Kit Borg Warner Billet 66mm -Twin Wastegate Aiming around 600WHP!
Cruising in Greece
Nikolas
Stunning car mate :)
Hello to all,
Cruising in Greece
Nikolas
Added dude :thumbs:
  • 2 weeks later...
I'm going to be going in a slightly different direction with my build and so I MAY have the following items up for grabs-
Brand new T70 T3 oil lubricated turbo
XS power T4 NA-T manifold
XS power 3" Down pipe
XS power wastegate
7MGTE 440cc injectors
1 x stock manual NA ECU
Would there be any interest?
My build is an na-t :D ;)
- - - Updated - - -
XS power wastegate
Pm Aspire mate he will need most of that ;)
