David P Posted January 10, 2013 Share Posted January 10, 2013 (edited) Mine is 11.5lbs (.8 Bar) 352 fwbhp, will be raising closer to 14.7lbs (1 Bar). Edited January 10, 2013 by David P (see edit history) Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted January 10, 2013 Share Posted January 10, 2013 The spec i going to for is xs power kit with the greddy emanage ultimate ecu, got some money saved already so getting their slowly only thing i confused on is: 1. Where does the 3bar map sensor go and whats it for? 2. What happens to my 02 sensors and cant see where they will go xs power kit am looking at? Quote Link to comment Share on other sites More sharing options...
masterfett Posted January 10, 2013 Share Posted January 10, 2013 Going this route with my N/A after summer, so this thread was an excellent find for me Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 10, 2013 Share Posted January 10, 2013 (edited) The spec i going to for is xs power kit with the greddy emanage ultimate ecu, got some money saved already so getting their slowly only thing i confused on is: 1. Where does the 3bar map sensor go and whats it for? 2. What happens to my 02 sensors and cant see where they will go xs power kit am looking at? Hi fella! 3bar map sensor. If you look at the back of the engine you will see a square gadget on the back wall, it has a black vacume line comming out from the underneath and a connecter plugged in the front. This is your stock map sensor so you need to keep it if your going piggy back like myself. Take the vacume hose and cut it near to the Map sensor itself then insert a T-piece, then connect your greddy 3bar map sensor vacume line to that T-piece. Then the eclectical connector on your 3 bar map sensor plugs into the side of your greddy emanage. Job done This is what it looks like : Edited January 10, 2013 by FOSTA (see edit history) Quote Link to comment Share on other sites More sharing options...
d-_-b Posted January 10, 2013 Author Share Posted January 10, 2013 Hi fella! 3bar map sensor. If you look at the back of the engine you will see a square gadget on the back wall, it has a black vacume line comming out from the underneath and a connecter plugged in the side. This is your stock map sensor so you need to keep it if your going piggy back like myself. Take the vacume hose and cut it near to the Map sensor itself then insert a T-piece, then connect your greddy 3bar map sensor vacume line to that T-piece. Then the eclectical connector on your 3 bar map sensor plugs into the side of your greddy emanage. Job done Nice reply dude Little bits of info like this am hoping to build up a collection of Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 10, 2013 Share Posted January 10, 2013 b;3575419']Nice reply dude Little bits of info like this am hoping to build up a collection of Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted January 10, 2013 Share Posted January 10, 2013 Thanx fosta, this is great for all little bits of information to help us wanting to go na-t Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 10, 2013 Share Posted January 10, 2013 Updated with a picture of what the stock map sensor actually looks like. Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted January 11, 2013 Share Posted January 11, 2013 Thats great help mate thanks again Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 11, 2013 Share Posted January 11, 2013 Thats great help mate thanks again If you look to the left in that picture you will see a shiny round metal object. That's my 3 bar map sensor Quote Link to comment Share on other sites More sharing options...
Suprakeith Posted January 11, 2013 Share Posted January 11, 2013 i see it bud, the bits are starting to click together Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted January 11, 2013 Share Posted January 11, 2013 Can anyone clear up the 02 sensor mod.. I planned to weld a 2nd bung on but I can't imagine there being much space with my 4" down pipe? Is it as simple as cutting one 02 sensor off and joining the wires to the other, or is it more complicated ecu wiring job? Quote Link to comment Share on other sites More sharing options...
TRD-1 Posted January 11, 2013 Share Posted January 11, 2013 Running NA-T: 1. tkddav3 2. -Welsh-Stealth- 3. Pulley 4. Fosta 5. Pjavon 6. Fixcz 7. Pulley 8. Abtin90 NA-T Builds: 1. d[-_-]b 2. Caineoo 3. Fosta (target: 600+bhp NA-T build) 4. Rich.2211 5. Josh42 6. -Welsh-Stealth- (target: 600+bhp NA-T build) 7. Pulley (target: 600+bhp NA-T build) 8. Ballsdeep 9. Al Massey 10. TRD-1 Hey Guys, add me in to, Im doin a build on clubaristo.net where im hoping to run my NA-T with a TT ECU and few other TT engine parts. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 11, 2013 Share Posted January 11, 2013 Can anyone clear up the 02 sensor mod.. I planned to weld a 2nd bung on but I can't imagine there being much space with my 4" down pipe? Is it as simple as cutting one 02 sensor off and joining the wires to the other, or is it more complicated ecu wiring job? Hi mate, you can do this 2 ways. 1. Buy universal bosh single wire threaded lambda sensors and just replace the existing ones with these new ones. ( you will need to cut the conector plugs off the old sensors and solder the wire from the plugs onto the new sensors so its then plug and play. 2. If you want to run you stock sensors then you will need to have a plate or plates made up and welded on. I decided to run only one sensor so I took the gasket from my stock sensors off and took them to a engineering shop, I told them to make the plate the same size as the gasket and weld it on. They also drilled the hole out and put the 2 threads in so mine just bolts in now. Cost me £20 to have done. Then for the wires I cut the connector off the second sensor I wasn't using then soldered it on to the 1 sensor I was using so this sensor now had 2 conectors on it. Then just plug them in. This way you the ecu sees the same signal from both lambda sensor signal wires. Job done Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted January 11, 2013 Share Posted January 11, 2013 cheers pal, think option 2 will work well with my down pipe, it already has a bung for the stock sensor so saves me having another welded on. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 11, 2013 Share Posted January 11, 2013 Top stuff mate Quote Link to comment Share on other sites More sharing options...
fixcz Posted January 11, 2013 Share Posted January 11, 2013 (edited) hey fly:Dbefore after Edited January 11, 2013 by fixcz (see edit history) Quote Link to comment Share on other sites More sharing options...
fixcz Posted January 11, 2013 Share Posted January 11, 2013 hi mains run like this 2 single wire o2 sensor 1 use for afr sensor and 2 connect ecugreat start to this topic with lots of good info already from builders to prospective builders. Good news though as my Westfield has just driven away so im now in the market for a Supra to go NA-T. Keeping beedy eyes on this subject. Can anyone clear up the 02 sensor mod.. I planned to weld a 2nd bung on but I can't imagine there being much space with my 4" down pipe? Is it as simple as cutting one 02 sensor off and joining the wires to the other, or is it more complicated ecu wiring job? Quote Link to comment Share on other sites More sharing options...
Fly Posted January 12, 2013 Share Posted January 12, 2013 hey fly:Dbefore[ATTACH=CONFIG]162742[/ATTACH] after[ATTACH=CONFIG]162743[/ATTACH] Nice, I take it you liked the idea of having a roof too !! Quote Link to comment Share on other sites More sharing options...
pjavon Posted January 12, 2013 Share Posted January 12, 2013 (edited) Haha, great minds think a like;) Before After Edited January 12, 2013 by pjavon (see edit history) Quote Link to comment Share on other sites More sharing options...
Fly Posted January 12, 2013 Share Posted January 12, 2013 How do you boys find the supra performance against your old kit cars, is it similar or do you miss the mental power . Sorry slightly off topic Quote Link to comment Share on other sites More sharing options...
pjavon Posted January 12, 2013 Share Posted January 12, 2013 It depends what you mean by performance to be honest. If you mean just outright power then up to about 80mph the kitcar would come out top as there so quick off the mark. At motorway speed roll on's once into 3 figures the kitcar would get slaughtered, mine would anyway:d. Totally different worlds in my opinion and pretty hard to compare as it depends on which way you want to look at it. Round a track it'd be like comparing keira knightley to susan boyle:d, unless it was full of long straights;). Mind you theres a guy on here who I think could well of beat me around Oulton Park in his Supra after watching his video's, he is a very good driver with a well set up supra though. This is what the lad that bought mine ended up doing to it:(, island bend at Oulton park won!! Quote Link to comment Share on other sites More sharing options...
Fly Posted January 12, 2013 Share Posted January 12, 2013 Yea I tend to agree my Westfield was good to about 90 then ran out of drive, due to the 1.6 gearbox though looking at Kaan,s supra I'm sure a well set up supra would be much slower to 90 and then destroy the kit car beyond . Quote Link to comment Share on other sites More sharing options...
3LL Posted January 12, 2013 Share Posted January 12, 2013 Im looking at going NA/T this year. Was looking at using XSpower setup, but unsure as have heard both good and bad things. the trouble is I dont have the knowledge to build a kit up myself though and some of the other "complete" kits are stupidly expensive.. would welcome guidance off any kind soul in this thread who can help me get a shopping list together.. Im not looking for stupidly high gains, I would be very happy with 350 RWHP. I suppose the first question I have is what does the NA Autobox support , I have heard some folks say anything over 270HP and its a gamble.. if thats the case what did some of you convertee's do when you went to NA/t on your Auto? Quote Link to comment Share on other sites More sharing options...
David P Posted January 12, 2013 Share Posted January 12, 2013 Im looking at going NA/T this year. I suppose the first question I have is what does the NA Autobox support , I have heard some folks say anything over 270HP and its a gamble.. if thats the case what did some of you convertee's do when you went to NA/t on your Auto? I built my own gearbox. http://www.mkivsupra.net/vbb/group.php?groupid=57 Quote Link to comment Share on other sites More sharing options...
