Jspec Germany Posted August 14, 2005 Share Posted August 14, 2005 Subframe bolt torque specifications, specifically the scanned in maintenance manual in another thread: edited - http://www.mkivsupra.net/vbb/showthread.php?t=12703 There's a link inside this thread that should show you the section I'm talking about. The picture shows the forward two of the rear subframe bolts being torqued to 196 Nm while the text to the right says 175 Nm (129 ft/lbs). Which is it, the 196 or the 175? Thanks, this is getting done first thing in the morning. Quote Link to comment Share on other sites More sharing options...
kosmic Posted August 14, 2005 Share Posted August 14, 2005 dead link Quote Link to comment Share on other sites More sharing options...
Jspec Germany Posted August 14, 2005 Author Share Posted August 14, 2005 edited to: http://www.mkivsupra.net/vbb/showthread.php?t=12703 Quote Link to comment Share on other sites More sharing options...
merckx Posted August 14, 2005 Share Posted August 14, 2005 http://www.mkiv.com/manual/manualtt/general_maintenance/mo14.jpg It's not obvious from the pic, not that critical as they aren't ball joints or bushes. I would tighten them to 196 Nm to be sure. The other ones at the rear aren't obvious either, is it 43Nm or 43 ftlbs. 43 ftlbs sounds more like it though. Quote Link to comment Share on other sites More sharing options...
Jspec Germany Posted August 15, 2005 Author Share Posted August 15, 2005 If you divide the ft lb number by the Nm number you will get close to .74 each time. This leads me to believe those numbers are more accurate to the right and that the numbers in the figure are incorrect. Quote Link to comment Share on other sites More sharing options...
