neil Posted January 6, 2013 Share Posted January 6, 2013 (edited) Hi all Witch marks tdc Edited January 6, 2013 by neil (see edit history) Quote Link to comment Share on other sites More sharing options...
listy Posted January 6, 2013 Share Posted January 6, 2013 Comes off anti clockwise iirc. You are on about the crank pulley bolt, yes? Quote Link to comment Share on other sites More sharing options...
neil Posted January 6, 2013 Author Share Posted January 6, 2013 Yes mate crank pully bolt Quote Link to comment Share on other sites More sharing options...
listy Posted January 6, 2013 Share Posted January 6, 2013 I worked it out by the way I got mine off. So think I'm right lol. Breaker bar on it, sitting on the floor passenger side, and cranked it over. So the crank goes clockwise, otherwise the bar would go flying, so must be an anti clockwise thread Quote Link to comment Share on other sites More sharing options...
neil Posted January 6, 2013 Author Share Posted January 6, 2013 Witch marks tdc (top dead centre) the dot or line Quote Link to comment Share on other sites More sharing options...
listy Posted January 6, 2013 Share Posted January 6, 2013 That's a cam pulley mate Not sure on the thread on that..... Quote Link to comment Share on other sites More sharing options...
neil Posted January 6, 2013 Author Share Posted January 6, 2013 Yea I got the that off lol thanks to your help I want to do the timing so I need to tdc it Quote Link to comment Share on other sites More sharing options...
FOSTA Posted January 6, 2013 Share Posted January 6, 2013 The line mate Quote Link to comment Share on other sites More sharing options...
Hartmann Posted January 6, 2013 Share Posted January 6, 2013 "Just want to clarify a critical step so no one gets into trouble. You technically do not want to be set for TDC! You want it to be 60 degrees BTDC (before top dead center). If you happen to accidentally spin the cams while the motor is at TDC, it would be a really bad thing. With the motor at 60 degrees BTDC, you could spin either cam independently of the crank and things will not interfere. For clarity: 1) Set motor to TDC by aligning the crankshaft groove with timing mark '0'. 2) Check that the camshaft timing pulleys notch is aligned to the timing cover. 2a) If not, turn the crankshaft 1 full revolution (360 degrees). The crank and camshafts should now be aligned 3) Turn crankshaft pulley 60 degrees counterclockwise to place sub timing groove on the crankshaft at mark '0' 4) This should align the camshafts pulley DOTs with the timing cover" Quote Link to comment Share on other sites More sharing options...
