mark newman Posted January 3, 2013 Share Posted January 3, 2013 I'm looking to put on a engine stabilizer for my setup, But i cannot find where to get one from. I want one just like in the pic below, Any help? Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 3, 2013 Share Posted January 3, 2013 eBay mate Quote Link to comment Share on other sites More sharing options...
Ian C Posted January 3, 2013 Share Posted January 3, 2013 I have to ask, what on earth is that supposed to be for Why wouldn't you want your engine to be able to move on the mounts? And if you don't, fit solid engine mounts. I wouldn't expect a single M6 bolt with a short shank into aluminium to a) be rigid and b) last 5 minutes before stripping the thread Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 3, 2013 Author Share Posted January 3, 2013 eBay mate Got any links? i cant find them I have to ask, what on earth is that supposed to be for Why wouldn't you want your engine to be able to move on the mounts? And if you don't, fit solid engine mounts. I wouldn't expect a single M6 bolt with a short shank into aluminium to a) be rigid and b) last 5 minutes before stripping the thread It's to stop the engine twisting to much and putting stress on the gearbox which caused my last box to let go. You wouldnt need it on the street but on the drag strip the engine moves quite abit when shifting gear Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted January 3, 2013 Share Posted January 3, 2013 http://www.ebay.co.uk/itm/Mazda-RX7-Engine-Damper-Brace-kit-/140695032111?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item20c213d12f Mines a fosters. Cheers Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 3, 2013 Share Posted January 3, 2013 I have a weapon r on mine http://www.ebay.co.uk/itm/WEAPON-R-ENGINE-TORQUE-DAMPER-93-98-TOYOTA-SUPRA-TURBO-/300404093347?pt=Motors_Car_Truck_Parts_Accessories&hash=item45f17ab1a3 Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 3, 2013 Share Posted January 3, 2013 I have to ask, what on earth is that supposed to be for Why wouldn't you want your engine to be able to move on the mounts? And if you don't, fit solid engine mounts. I wouldn't expect a single M6 bolt with a short shank into aluminium to a) be rigid and b) last 5 minutes before stripping the thread I once made the mistake of fitting one of those ebay so called "dampers" many years ago, needles to say I came off quite quickly when i realised that the horrible vibration that was being transmitted though the bodywork was down to that. If you really want a proper "damper" then at least fit something like the old BMWs used to use, or a mountain bike damper, at least you wil stand a chance of it actually achieving what its supposed to do. Quote Link to comment Share on other sites More sharing options...
David P Posted January 3, 2013 Share Posted January 3, 2013 I have a weapon r on mine http://www.ebay.co.uk/itm/WEAPON-R-ENGINE-TORQUE-DAMPER-93-98-TOYOTA-SUPRA-TURBO-/300404093347?pt=Motors_Car_Truck_Parts_Accessories&hash=item45f17ab1a3 Did she fit yours? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted January 3, 2013 Share Posted January 3, 2013 Did she fit yours? http://www.mkivsupra.net/vbb/attachment.php?attachmentid=162475&d=1357243710 She fit great! Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 3, 2013 Author Share Posted January 3, 2013 I have a weapon r on mine http://www.ebay.co.uk/itm/WEAPON-R-ENGINE-TORQUE-DAMPER-93-98-TOYOTA-SUPRA-TURBO-/300404093347?pt=Motors_Car_Truck_Parts_Accessories&hash=item45f17ab1a3 yes just seen that one have you got a pic of it fitted , as i can not see one fitted . Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 3, 2013 Share Posted January 3, 2013 yes just seen that one have you got a pic of it fitted , as i can not see one fitted . I can get a PIC tomorrow, don't have any off hand These are for lefthand drive cars, I needed to cut and reweld the bracket the damper bolts to on the strut; other than that it was a perfect fit Quote Link to comment Share on other sites More sharing options...
Mario Posted January 3, 2013 Share Posted January 3, 2013 Interesting thing didn't knew that the movement of the engine can break boxes.. Did a search as i found it quite interesting. Engine torque damper weapon r for 2jz-gte http://www.turbowholesale.com/Weapon-R-Toyota-Supra-Turbo-1993-98-Engine-Torque-Damper-Kit.html http://www.japanerfusk.dk/CIMG0804.JPG Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 3, 2013 Author Share Posted January 3, 2013 I can get a PIC tomorrow, don't have any off hand These are for lefthand drive cars, I needed to cut and reweld the bracket the damper bolts to on the strut; other than that it was a perfect fit ok that wuld be great , do you think it work with a big single being a lefthand drive. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted January 3, 2013 Share Posted January 3, 2013 Why not fit the proper tool for the job......uprated engine mounts. Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 3, 2013 Author Share Posted January 3, 2013 Interesting thing didn't knew that the movement of the engine can break boxes.. Did a search as i found it quite interesting. Engine torque damper weapon r for 2jz-gte http://www.turbowholesale.com/Weapon-R-Toyota-Supra-Turbo-1993-98-Engine-Torque-Damper-Kit.html http://www.japanerfusk.dk/CIMG0804.JPG look at this http://www.supraforums.com/forum/showthread.php?674246-V160-case-broke.&daysprune=365 Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 3, 2013 Share Posted January 3, 2013 ok that wuld be great , do you think it work with a big single being a lefthand drive. She bolts onto the strut and into two OEM threaded points on the stock intake; not too sure if you have a stock intake? Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 3, 2013 Author Share Posted January 3, 2013 Why not fit the proper tool for the job......uprated engine mounts. mybe I will but the vibration through the body of the car I would hate. Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 3, 2013 Author Share Posted January 3, 2013 She bolts onto the strut and into two OEM threaded points on the stock intake; not too sure if you have a stock intake? looks good but will not fit mine as no stock intake . Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 3, 2013 Author Share Posted January 3, 2013 Interesting thing didn't knew that the movement of the engine can break boxes.. Did a search as i found it quite interesting. Engine torque damper weapon r for 2jz-gte http://www.turbowholesale.com/Weapon-R-Toyota-Supra-Turbo-1993-98-Engine-Torque-Damper-Kit.html http://www.japanerfusk.dk/CIMG0804.JPG wow that is clean, well done . Quote Link to comment Share on other sites More sharing options...
Mario Posted January 3, 2013 Share Posted January 3, 2013 look at this http://www.supraforums.com/forum/showthread.php?674246-V160-case-broke.&daysprune=365 wow, never knew about that, thanks for the link! Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 3, 2013 Share Posted January 3, 2013 With it on, I did notice I could go through the gears a lot smooth; the gearbox doesn't move around as much Quote Link to comment Share on other sites More sharing options...
JamieP Posted January 3, 2013 Share Posted January 3, 2013 For a drag car, I'd solid mount the engine, phr make some. Quote Link to comment Share on other sites More sharing options...
mark newman Posted January 3, 2013 Author Share Posted January 3, 2013 For a drag car, I'd solid mount the engine, phr make some. mybe that what I will do but its still a street car and still goes to Tesco for the shopping . Quote Link to comment Share on other sites More sharing options...
Jellybean Posted January 5, 2013 Share Posted January 5, 2013 Some pics on a rhd Supra Quote Link to comment Share on other sites More sharing options...
