Steviekid Posted August 14, 2005 Share Posted August 14, 2005 I've been reading through loads of old threads but can't seem to find the answer to whats probably a stupid question! What I'm trying to find out is whats the difference between stage 1,2 and 3 hybrids? Its really beginning to annoy me now Quote Link to comment Share on other sites More sharing options...
Kopite Posted August 14, 2005 Share Posted August 14, 2005 not a lot of differance apparently Quote Link to comment Share on other sites More sharing options...
Gazboy Posted August 14, 2005 Share Posted August 14, 2005 I've been reading through loads of old threads but can't seem to find the answer to whats probably a stupid question! What I'm trying to find out is whats the difference between stage 1,2 and 3 hybrids? Its really beginning to annoy me now Trying to find any info on Hybrids is damn near impossible... Quote Link to comment Share on other sites More sharing options...
Bob Posted August 15, 2005 Share Posted August 15, 2005 Have you tried contacting turbo technics or AET? From what I've gleaned, stage 2 hybrids will have larger turbine and compressor wheels which should be good for another 100bhp or so (according to AET). Quote Link to comment Share on other sites More sharing options...
JohnA Posted August 15, 2005 Share Posted August 15, 2005 I would enquire if either of the aforementioned establishments provide compressor maps for their various specially designed hybrids. That would be the first port of call in my view. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted August 15, 2005 Share Posted August 15, 2005 Right the stages were started by Leon Green @ JPS Motorsport. Anyone else selling them in stages as just copied the name etc. The Stages simply refer to the size of compressor wheel that has been squeezed into the stock housing. AFAIK the hot side of the turbo is as standard but some may change it. Also in some turbo's the wastegate flap has been enlarge to try to reduce the boost spiking. It helps but doesnt cure. I think they all run 360 degree bearings. Quote Link to comment Share on other sites More sharing options...
Dragonball Posted August 15, 2005 Share Posted August 15, 2005 Hybrided turbos can be made to the specification that you desire (obviously within confines of the existing phsical size) - and as Terry says the terms 1/2/3 were used before to associate with various performance criteria Near stock - less lag Much enlarge - higher lag Depends if you require pseudo UK spec spooling (same sizes but metal fins etc) or higher end performance (approx 50HP increase) through boring out All mine are 360, balanced and warranties supplied Quote Link to comment Share on other sites More sharing options...
