Help :( Headgasket set
Caineoo
It will, but it alters the compression ratio I think. Part number for the full set is: 04112-46056 from Toyota. This is for a TT set, but you get all the gaskets for cam covers, stem seals etc. I've actually got part of a new set including the headgasket if you're interested? I bought the full kit when I did my stem seals and cam cover gaskets, but it worked out cheaper to buy the full set as opposed to separates.
That! Same cut out pattern just different thickness. What CR you aiming for?
Thanks for the replies.
Dan i am interested for sure buddy. Whats left of the set? And yeah i realise the compression ratio part as this is the plan :D to lower it down.
I'll double check, but headgasket, intake gaskets and turbo gaskets are definitely there. The cam end seals, valve stem seals and cam cover seals have been used. PM your email, I'll get some pics and send through what's still there.
