NA-T Driveway Special
Pulley
During refurb
Took ages to polish the rims, I'm lucky I have all the polishing equipment at work at my disposal :)
These are fairly rare blitz 03 3 piece split rims, pretty light wheels
I'm currently machining up some Ali rings that sit between the two rim halfs to widen the wheels so I can run 335 rears :)
Edited by Pulley (see edit history)
  • 1 month later...
  • Replies 273
Posted Images
Have I missed a post mate? I see your sig says 750whp but don't see anything about mapping or dyno graph?
Before we sold up our cnc mills lathes engine and rolling dyna I had my own dynamometer facilities where I "mapped" and setup my engine both out and in my car, I'm planning on using stanton motorsport who aren't too far away from me now for future development and also to give me dyno graphs to show on here
I'm currently running a fully cnc ported head with 1mm oversize valves, and my own custom weld/reground cams
Haven't updated or posted pics and stuff in here lately, work has been so busy and having too much fun driving lol
This is my 2013 setup
(Probably forgot loads)
NGK #8 irridiums
Magnecore 10mm leads + coil
Enhanced resolution dizzy pickup
Denso 330 primaries
SARD 2000cc secondaries
Dual fuel rails + fprs
Dual fuel lines
Stock NA block pistons rods
Triple pumps with own cnc hanger
Arp con + head bolts + flywheel bolts
V160 with own custom quickshift
Osgiken triple plate
Trd diff
own Fully cnc ported head
Ferrea oversize valve set
Ferrea bronz valve guides and seals
Double spring and titanium retainers
Own custom weld, re-ground 280 cams
Own custom turbo manifold with HKS wg
Own custom downpipe with flexi and wg plumbed in
Own qs valve with ceramic bearing
Greddy oil cooler and thermostat
Forge 4" intercooler and bov
Own custom 3" inlet piping
Custom modified and ported TT FFIM plenum
Tein coilovers with EDFC
TT arbs
Blitz nur spec r
Blitz 03 with custom wider rear barrels 315's
All manor of other custom machines n fabricated stuff
Plans for 2014
Full strip and bare shell respray-white
Fully refurb n shotblast / powdercoat subframes and everything
Big brakes fit
Possibly fit nicer clutch
Drop in my fully built block
Fit my own custom plenum + 4" tb
Battery to boot
Decide on bigger turbo possibly
Get syvecs
Develop own twin turbo and use syvecs to controll valving
Get lots of shiney dyno sheets to post on here
sounds good, any videos? must be near on 900bhp?
Tbh the current stock bottom end and especially NA pistons are holding on for dear life at 750 rwhp
I can only put their existence down to better head flow and breathing allowing for controlled egt and burn temps
I even endoscoped the bores/pistons re entry expecting carnage but all is surprisingly healthy
I need to really go to lee or some other decent mapper once I've got syvecs and then I can video rather than map myself
My setup by your standards is outdated and crude, very DIY
2014 will be better documented and video'd
And I look forewards to doing some club dyno runs
  • 1 month later...
Haha, was inevitable really, but I have confirmed today that my bottom end has let go!
Number 6 con is bent and the bolts let go
I'd decided to take it off the road for an engine swap anyway but this has just made it a necessity
So ill be putting a built bottom end in that should be far better suited to the Bhp I'd like to run
I'm also considering adding oil squirters but am in decided and will be asking those in the know on here wot their thoughts are
For the record I can find no evidence of det or overheating pistons , bores also measure up and show no signs of bore wash
I will also be going coil on plug and perhaps even syvecs now as my current fuelling was only meant to be an experiment
Pics to follow of my twin injector custom flowed plenum I'm developing with 4" tb
(Similar to Hypertune but with second rail mounted below top rail at steeper angle)
I think you will need an S8 for 12 injectors?
That's one option and by far the easiest , linking two stock ecu's with additional piggy back is quite a complex setup and I think I'd rather just buy off the shelf and plug n play
Also the other advantages of the syvecs system that I plan to take advantage of later in the year
Still impressed it lasted so long considering the fun you've had in her ;)
Tbh I mostly drove it at 1.2-1.3 bar which worked out at 600ish
1.8 bar war just brutal and tbh even on dry roads I found it difficult to actually use it
And it destroyed my trd diff, and killed my driveshaft
600-650 is a nice figure I think
So although I'm building to be able to run high figure, I'll just run around at 600 for the most part
  • 1 month later...
Custom plenum almost finished, just machining secondary row of injectors to run below the runners
Will be 550cc tops and 1000cc bottom row, using large bore sard rails and each with its own pump regulator and fuel lines
