Guest Danger Mouse Posted December 30, 2012 Share Posted December 30, 2012 I have a TT with the veilside overfenders and rolled arches. I am looking to buy the following wheels and wanted to know if they will fit. Front arches are perhaps 25-30mm wider with the fenders on.. Rears about 80mm+ wider So 18x9.5 Et20 fronts 18x10 Et15 rears My alternative front options would be to go 8.5J fronts with the same offset or 9.5J with Et30 offset...? Advice welcome Cheers in advance Quote Link to comment Share on other sites More sharing options...
Nic Posted December 31, 2012 Share Posted December 31, 2012 I have a TT with the veilside overfenders and rolled arches. I am looking to buy the following wheels and wanted to know if they will fit. Front arches are perhaps 25-30mm wider with the fenders on.. Rears about 80mm+ wider So 18x9.5 Et20 fronts 18x10 Et15 rears With 25mm front arches the wheels would sit around 5mm in from flush. With 80cm rear arches the wheels would sit around 60mm in from flush. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 31, 2012 Share Posted December 31, 2012 I have VS overfenders on the rear with a 12J et20 wheel and 20mm spacers they fit flush. Quote Link to comment Share on other sites More sharing options...
Guest Danger Mouse Posted December 31, 2012 Share Posted December 31, 2012 Thanks guys. I wanted to go 12J rears but funds wont allow. The rears will clear easily but i do have concerns about the fronts... But if Nic is right, then i can live with a close call.... I am running tein super streets so have some variance in height and dampening settings! Quote Link to comment Share on other sites More sharing options...
Guest Danger Mouse Posted December 31, 2012 Share Posted December 31, 2012 I went for 18x9.5 ET30 for some safety margins in the end.... Quote Link to comment Share on other sites More sharing options...
