NA-T guys query - TT intake manifold onto N/A head
d-_-b
Hey guys, I'm not sure how many have done this but hopefully a few have knowledge of this..
What is required to do this? I know;
the intake runners need to be cut & welded
pas moved
Battery moved?
But what needs to be done for the sensors ?
Cheers for any help with this fellas!
It's not a simple job, I've done it, on the sensors you just use the TT throttle position sensor and invert the wires , eg pin 1234 go to wires 4321
I used a mk3 idle control valve (same fitting to the TT plenum as the Mkiv one and same wiring as NA idle valve)
And ofcourse you don't use the secondary throttle position sensor and traction control stepper motor (butterfly at front of TT throttle body)
Aligning and porting the NA runners - TT plenum ports isn't a straight foreword job, and you'll also need a remote reservoir pipe fitting for your power steering pump (expensive from Toyota)
Hope this helps
