Cloud of blue smoke at start up
suprakid95
hello, this problem has been bothering me ever since i have purchased this car. So my problem persists as following. Car is a TT JDM mkiv auto supra with 68 000 miles all original miles, bone stock absolutely no modifications what so ever to the car. So when i let the car sit for more than 3 days, it will have blue smoke when i first start it up cold, and it will go away after its done blowing it out. I made a video so click on it below to see it. Once the car has been started i can shut it off right away and it wont smoke again at start up. I let it warm up at idle and rev it all the way to 6K and there is no sign what so ever of blue smoke while revving and after i let off the gas pedal there is no blue smoke neither, when im driving the car and floor it all the way to 6K i have gotten my friend to follow behind me, while i stayed on it (hes got a supra as well) and his window was down, and he saw no trace of blue smoke, or any smell of blue smoke while i was accelerating and letting off. Yet i noticed that after 2 tanks of gas, it has burned 250ML of oil. If i let the car sit for 1 day and go to start it up cold there is no trace of blue smoke at start up. I have also took off the charge pipe for the intercooler and there was a small puddle of oil, but nothing crazy or dripping out. I took out my filter and noticed a puddle of oil in the air box, and noticed how the oil has dripped down the air box into the airbox were it formed a puddle. Here in the video your about to see is a very cold start up were the car has been sitting for 7 straight days un-touched and un-started, it was quite cold outside as well little bit below freezing. I am confused on what could be causing my blue smoke at start up. My two guesses is my turbo seals are going out, or its my valve stem seals, or its both. I need some input please
what about me finding a puddle of oil in my air box?? wouldnt that be coming from the turbo's ??? I will make another video today, of my revving the car all the way to 6K just to make sure there is no oil coming out on acceleration or deceleration. Another thing i have noticed when i was changing the sparkplugs, is that someone else in Japan took off the valve covers for what ever reason. I wonder if they fixed the valve stem seals, or simply replaced the valve cover Seal.
Edited by suprakid95 (see edit history)
Depends how much you love the car, but you could do the valve steam seals and convert the car to a 6 speed manual for around the same price as buying a good TT6 and tbh if you've got the money to buy a TT6 you'd be much better of fixing this one as with the Valve steam seals going I doubt you'd get more then about 4k for the car.
Hmm thats weird, because here in canada i can get around 6K for the car, and a TT 6 speed is about 8700K. So im not sure on what to do. I love the car, but i just want a 6 speed manual. how much is a 6 Speed V160 over there??
Roughly £3,000 for a 6 speed box, then you have to think about clutch puddle, clutch and labour for fitting so all in all I would say it is closer to £5k including labour.
An as mentioned above it is the valve stem seals, small parts to replace but costly job. Their is a thread on here on how to do it.
In a stock air box, no, maybe just a misting. Serious oil contamination of the air intake side is either excess crankcase blow by via the damnable positive crankcase ventilation system, or very bad turbo seals on the compressor side. It's very easy for people to say "Oh, that's valve stem oil seals". Believe me, blue smoke on start up can be EXTREMELY hard to diagnose, hence me suggesting you ignore it until it becomes chronic, or you need to pull the engine for a full overhaul. If you want a stab at a repair I'd suggest a new PCV valve, and new valve stem oil seals done with the head in situ. That's, relatively speaking, a cheap repair, and you may get lucky. Otherwise two new turbos at over 1200 UK Sterling plus taxes each, and a re-bore and new pistons should fix the other two suspects ;) Sadly £30,000 cars don't get any cheaper to fix even when they cost £30. Seriously, I'd ignore for now.
thanks for the reply. Here is a picture of what i did.
as u can see were the tip of that red bubble is pointing to the exhaust side PCV, my supra buddy told me to take off that hose, and install a small K&N air filter on it, and cap the other end. And so i did. I would like to say that since then i have noticed the oil in my airbox but i cannot be so sure about that, as i noticed that motor oil was in my air box couple months ago, i believe i noticed that a month after i put the little filter on the PCV, and i noticed accidentally while checking my air filter to see how clean it still was. I have also noticed that when the car arrived here in Canada from japan, it didnt burn a drop of oil, nor did it have any smoke at start-up as soon as i went to pick it up. as soon as i dumped the old motor oil out of the car, i noticed that there was smoke at start up, then month later noticed the oil in my airbox. I used Castrol 10W-30 Fully Synthetic is what motor oil is in the car currently. However with the old oil car didnt have any oil in the airbox ( and i drove it for a week with old motor oil) nor did it have any blue smoke at start-up with the old oil. Something fishy is going on with it
Also here is a picture, when i took off the intercooler piping, when it had the oil motor oil in it. Clean as whistle
Then after i changed the motor oil, a week later i took off the intercooler pipe and noticed a very small amount of oil there which all of that oil was very black and my motor oil was clean as a whistle, and the oil that i found in there it wasnt even a cup full. I will take some time to take off the intercooler piping once again sometime this week to show the amount of motor oil in there
You will ALWAYS get some oil in the intake. You haven't done the PCV valve removal correctly. I would buy a new one and refit the stock plumbing. Oil wise people can and do witter endlessly. If the rings and stem seals are a bit tired I'd go to something like a 15 / 50 or even a * / 60 oil, but it might make no difference. Unless the intake pipes are awash with oil I really wouldn't worry too much. But I would reinstate the pCV valve unless you want to do a fair amount of work and fabrication adding bigger breather hoses and making an oil catch tank. personally I never run PCV systems on race or highly modded road car engines, but as yours is a stock engine, I'd keep the PCV valve set up stock as well.
I havent removed the PCV valve at all. All i did was i simply took the hose off on the exhaust side PCV and capped the the end of the turbo charge pipes, and on the actual PCV valve i put a K&N filter on it, only on the exhaust side, on the intake side i left it all stock. thats why im wondering where this oil in my intake box is coming from, its got my stock air filter on the bottom of it soaked in motor oil. The car has 68 000 miles, do the pistons rings get that worn out at 68 000 miles, or at this mileage get pretty much blown turbo seals???
