thomo8568 Posted December 19, 2012 Share Posted December 19, 2012 Hi I have a aem wideband gauge fitted to my NA, and from what I can remember about it it has an analog out put. Can I use this to replace one of the oem O2 sensor? Just to save me having to remove the manifold to get the mounting nut welded in. Cheers Quote Link to comment Share on other sites More sharing options...
msmile Posted December 19, 2012 Share Posted December 19, 2012 I have one as well, but i dont think the sensors are the same... The best is too google for oem lamda code, i believe its Bosch. Aem's is Bosch as well but they might have a different resistance so the output can be different and that can makes things even worse. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted December 19, 2012 Share Posted December 19, 2012 Not familiar with the AEM but i believe that it is capable of outputting a narrow-band simulation that can be inputted into the std ECU for lambda feedback, just like the Innovate wide-bands, so it should be fine, lambda sensors work on voltage, or more precisely in the case of narrow-bands 0.2v to 1.0v. Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 19, 2012 Share Posted December 19, 2012 Yes the white wire is the simulated narrowband output. But why the hell do you have a wideband on an N/A? Quote Link to comment Share on other sites More sharing options...
thomo8568 Posted December 20, 2012 Author Share Posted December 20, 2012 Thanks for the replys Don't think it will work then as think the output is 5v Will have to look in to this a bit more. Yes the white wire is the simulated narrowband output. But why the hell do you have a wideband on an N/A? I'm running a good amount of nitrous. So want to keep an eye out for it running lean. Quote Link to comment Share on other sites More sharing options...
mellonman Posted December 20, 2012 Share Posted December 20, 2012 AEM say they can simulate a narrow band but all can not ! my wideband cant manage to do it even put out the correct rage of voltage. have a look on the AEM forum even AEM say there are crap as a simulator FACT Quote Link to comment Share on other sites More sharing options...
Nodalmighty Posted December 20, 2012 Share Posted December 20, 2012 There is a pot that you access from the rear (jewellers screw driver is best) when you turn it you will see P0 to P4 appear on the display. One of these modes is the Narrow band simulation (0 - 1v). I wouldn't put a wide band to close to the manifold, 1/2 to 1 metre down the pipe is recommended by innovate. Lyndon. Quote Link to comment Share on other sites More sharing options...
