Kaan W Posted December 19, 2012 Share Posted December 19, 2012 Seems an odd question but does anyone else have a wire coming out the top of there diagnostics box? I have not seen this before but it was like it when I bought the car and havent got a clue what its for. Its just annoying me as it looks kind of messy and the wire just goes to the back of the engine somewhere but dont know if its to stop any lights flashing etc from aftermarket parts fitted. Any ideas chaps? Quote Link to comment Share on other sites More sharing options...
supra900bhp Posted December 19, 2012 Share Posted December 19, 2012 i got a clifford alarm with remote start and the fitter has got 1 wire going into mine now that was never there before so can only think its something to do with the immobiliser best take a good look before removing hope it helps? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 19, 2012 Author Share Posted December 19, 2012 i got a clifford alarm with remote start and the fitter has got 1 wire going into mine now that was never there before so can only think its something to do with the immobiliser best take a good look before removing hope it helps? Ah thats probably it then mate as I have a clifford remote start too. Thinking about it, it goes through the firewall in to the car so it most definately is that! Cheers fella Quote Link to comment Share on other sites More sharing options...
supra900bhp Posted December 19, 2012 Share Posted December 19, 2012 Ah thats probably it then mate as I have a clifford remote start too. Thinking about it, it goes through the firewall in to the car so it most definately is that! Cheers fella yeah mine dose the same fella but mine has been zip tied across the strut brace and go's down by brake servo into the car. well that was a easy fix Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 19, 2012 Author Share Posted December 19, 2012 yeah mine dose the same fella but mine has been zip tied across the strut brace and go's down by brake servo into the car. well that was a easy fix Yeah same as mate. I'll probably get a new cover for mine and run the wire downwards eventually for a cleaner look. Thanks for that Quote Link to comment Share on other sites More sharing options...
supra900bhp Posted December 19, 2012 Share Posted December 19, 2012 Yeah same as mate. I'll probably get a new cover for mine and run the wire downwards eventually for a cleaner look. Thanks for that same as me when I put engine back in after being the respray im gonna run it alot cleaner as looks poxy just zip tied to the trd brace sure the knob head done it to piss me off lol Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 20, 2012 Share Posted December 20, 2012 Which pin of the diagnostics plug is the wire attached to?! This reeks of a monster bodge Quote Link to comment Share on other sites More sharing options...
supra900bhp Posted December 20, 2012 Share Posted December 20, 2012 Which pin of the diagnostics plug is the wire attached to?! This reeks of a monster bodge Its locked away in my garage at the moe. I will find out sat and let you know mate. I not ever had a prob with any of it as of yet!! but you never know Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 21, 2012 Share Posted December 21, 2012 No pukka alarm install should have a wire wedged into the diag port, it'll be interesting to see which hole it's jammed into Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 21, 2012 Author Share Posted December 21, 2012 No pukka alarm install should have a wire wedged into the diag port, it'll be interesting to see which hole it's jammed into Just checked mine and it goes in to the -IG hole or IG-. Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 21, 2012 Share Posted December 21, 2012 That's the TACH signal, i.e. revs. If it's to do with remote start then it probably cuts the engine if the revs get higher than idle, i.e. someone is trying to drive off with the car. Was it too hard for them to tap into the main wiring loom then? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 21, 2012 Author Share Posted December 21, 2012 (edited) That's the TACH signal, i.e. revs. If it's to do with remote start then it probably cuts the engine if the revs get higher than idle, i.e. someone is trying to drive off with the car. Was it too hard for them to tap into the main wiring loom then? So where can I tap into the main loom that gives the same signal? Edited March 6, 2013 by Kaan W (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 6, 2013 Author Share Posted March 6, 2013 Anyone know? Im cleaning the mess of wires around the car and might aswel do this whilst everythings out. Quote Link to comment Share on other sites More sharing options...
David P Posted March 6, 2013 Share Posted March 6, 2013 With the wire there and doing what it's supposed to, you could tidily connect it into the loom below the block. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 6, 2013 Author Share Posted March 6, 2013 With the wire there and doing what it's supposed to, you could tidily connect it into the loom below the block. I could but there must be a better place for an alarm to tap in rather than going into the engine loom as Ian said. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 6, 2013 Share Posted March 6, 2013 couldnt you tap into the wire that goes to the ecu? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 6, 2013 Author Share Posted March 6, 2013 couldnt you tap into the wire that goes to the ecu? Thats what I was thinking, its just knowing what wire, I will have to look at some electrical diagrams. Quote Link to comment Share on other sites More sharing options...
