1uz v8 flywheel
dr_jekyll
You will need to weld up the original bolts holes and have it re drilled and the ring gear starter tooth engagement profile is on the wrong side. Farndon in covertry will make you a bespoke flywheel to your spec for £250 + vat You will need to provide the v8 flex plate so they can cut the ring gear off and attach to your new billet creation. Farndon do even better deals out side of motorsport season ;)
Lyndon.
