Does anyone know anything about BMWs?
AndrewOW
I've just bought a very nice BMW 318i estate for economy and practicality.
The car is really very nice, but has an odd problem.
Randomly when I come to a stop, traffic lights or a T-junction, the revs drop to a couple of hundred, then might cut out altogether.
I've read that it could be the camshaft sensor, but some guidance would be handy before I get everything pulled off to investigate it.
If anyone knows of a BMW specialist in Sussex, rather than BMW themselves, then I'd appreciate it. :)
Ah, it's a 2003 manual (E46 engine, I think). :)
E46 is the shape ;)
Possibly some sort of sensor but I'll check with a guy I work with who knows quite a bit about BMW's.
Couple of quick questions to help everyone on this thread.
* Does this only happen when the engine is warm?
* If you keep the revs up can you keep the engine from stalking or does it just stall no matter what you do?
* Last service?
It only does it when the engine is warm, and normally after a lengthy drive without stopping (like a decent A/B road, then up to a roundabout/t-junction), but not every time.
I think if I was quicker on the revs, I could keep the engine going.
The last service was done at the MOT which was in November, so not so long ago.
I'm going to call the garage where I bought it from tomorrow, but I drove it for ages and at least 10 miles in a very busy north London borough, so it had plenty of chances to do anything odd then, but was fine.
If you are able to ask your guy if he knows of anything more definite then great. :)
I joined bimmerforums.co.uk and had a good old look on there, but could be many things! Split hoses, camshaft sensor came up quite a few times.
When I had a Honda Prelude which had a weird ignition module problem, but that was during warm up. This happens when it's in full flow.
Edited by AndrewOW (see edit history)
Icv for sure. Usually located under the inlet manifold.
Pull it out clean it and run 12v across it to see if it opens
Thank you. If I can figure what that is and what it looks like, I might give it a go. A photo would help. :)
I'd usually offer for you to pop it into me mate and I could plug it in, however I wouldn't trust my diag kit as far as I could throw it atm! Although I get a new one today, so you're more than welcome to pop it in later in the week
Thank you. I may... :)
Drop AshBhp a message he is primarily a BMW specialist.
...if AshBhp isn't able to help. :)
UPDATE: I'd just like to thank Ben SZ-R for his invaluable help sorting my little problem out.
It turned out to be part of the airbox had dropped down on to a pulley wheel and rubbed a hole through the housing, causing an air leak.
I'm not sure if it was caused when the car was last serviced or not, but a small rubber lug type thing had either fallen off or had been omitted when reassembling it with a new air filter.
All great now though!
Thank you, Ben :)
