Easiest way to change dashboard vents?
Guest peter162
Guest peter162
I've got 2 vents falling apart on my dash. So got two replacements. One is the drivers ball vent and the other is passenger side square vent. Anyone got any advice on best way to get the old ones out? I have no idea. And don't fancy breaking my dash trying aha.
You should be able to get the passenger side vent out by removing the lower glove box (couple of screws), then undoing the top lid from inside. The Drivers side one I think you need to unbolt the lower panel which should allow you to see the ducting for the vent, hopefully you can pull that out (plastic bolt) and get to the vent.... hopefully...
