Kaan W Posted December 16, 2012 Share Posted December 16, 2012 (edited) So im just wondering as I hear alot about testing for codes and such could I test anything to see why the handbrake warning light is on? Ive checked brake fluid level, handbrake wires but dont know what else to check. Doors and boot are properly shut also if it makes a difference. Could it be something abs related as I had this unplugged when I took the front loom out? Or a fuse? Thanks in advance. Edited March 19, 2013 by Kaan W (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 17, 2012 Author Share Posted December 17, 2012 .. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted December 17, 2012 Share Posted December 17, 2012 Stock TC disabled? I'm sure that makes certain warning lights stay on? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 17, 2012 Author Share Posted December 17, 2012 Im not sure how the traction control works as done through syvecs but I have both warning (!) lights on. Not sure if the handbrake one is causing the other one to stay on tho. Quote Link to comment Share on other sites More sharing options...
DaveR Posted December 17, 2012 Share Posted December 17, 2012 I had a problem a couple of years ago where my brake fluid level dipped momentarily below the minimum mark (monged it on the weekly checks there!), which switched the handbrake and main warning lights (2 x ! ones as you say) on. I couldn't tell you precisely what was done to rectify it, but I know it was a fault code reset. A simple job if one has the kit, I believe. Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted December 17, 2012 Share Posted December 17, 2012 is the handbrake on?.... Quote Link to comment Share on other sites More sharing options...
stevie_b Posted December 17, 2012 Share Posted December 17, 2012 You haven't said if you've checked for error codes logged by the ECU. That's the best first step. Also, under what circumstances do the lights come on? Are they on as soon as you switch the ignition on, or do they come on after driving about for a while? Quote Link to comment Share on other sites More sharing options...
pbryant_knight Posted December 17, 2012 Share Posted December 17, 2012 Is it the handbrake warning light to the right or the triangular warning light in the centre? These supras are wired up really strangely. The triangular light comes on with the handbrake light, the door open etc. Could be any number of things. Check the handbrake switch under the console to make sure it's not stuck. Peter Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 18, 2012 Author Share Posted December 18, 2012 I had a problem a couple of years ago where my brake fluid level dipped momentarily below the minimum mark (monged it on the weekly checks there!), which switched the handbrake and main warning lights (2 x ! ones as you say) on. I couldn't tell you precisely what was done to rectify it, but I know it was a fault code reset. A simple job if one has the kit, I believe. Thanks for that I nedd to find out how to test for codes tho. is the handbrake on?.... Nope You haven't said if you've checked for error codes logged by the ECU. That's the best first step. Also, under what circumstances do the lights come on? Are they on as soon as you switch the ignition on, or do they come on after driving about for a while? There perminantly on all the time. Its probably just nothing but as said aboveI first need to know how to check for error codes. Is it the handbrake warning light to the right or the triangular warning light in the centre? These supras are wired up really strangely. The triangular light comes on with the handbrake light, the door open etc. Could be any number of things. Check the handbrake switch under the console to make sure it's not stuck. Peter Yeah thats the one. Thats what I mean once the handbrake light goes off the main one will probably go off too. Ive checked under the console but dont know what im looking for, I checked the connections but is there some kind of micro switch? Quote Link to comment Share on other sites More sharing options...
pbryant_knight Posted December 18, 2012 Share Posted December 18, 2012 Yeah, there is a switch under the handbrake. If you take the gear surround off you can see it and push it in and out manually. Quote Link to comment Share on other sites More sharing options...
GreaseMonkey Posted December 18, 2012 Share Posted December 18, 2012 Have you checked that the Stop lights work at the rear?, Just that some Toyota/ Lexus Vehicles bring this (Handbrake/ Brake warning light) light up if a Stop light bulb is out instead of the Bulb Failure Lamp. Also if it's not the above, may be worth to check the float on the Brake Fluid Level Sensor in the Brake Fluid Resevoir to see if its stuck down or check it for an open circuit, just a thought from previous stuff I've worked on with these symptoms. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 18, 2012 Author Share Posted December 18, 2012 Have you checked that the Stop lights work at the rear?, Just that some Toyota/ Lexus Vehicles bring this (Handbrake/ Brake warning light) light up if a Stop light bulb is out instead of the Bulb Failure Lamp. Also if it's not the above, may be worth to check the float on the Brake Fluid Level Sensor in the Brake Fluid Resevoir to see if its stuck down or check it for an open circuit, just a thought from previous stuff I've worked on with these symptoms. Thanks for that i'll check these out tomorrow. The rear lights are after market led lights but all work fine. I'll check the fluid level sensor circuit. Quote Link to comment Share on other sites More sharing options...
mellonman Posted December 19, 2012 Share Posted December 19, 2012 are you sure this is not from the syvecs being fitted ? i know that some ecu's put out the warning light in the cetre as you realsticly no long have a stock ecu fitted at all but still have the auto ecu Quote Link to comment Share on other sites More sharing options...
dukenukem Posted December 19, 2012 Share Posted December 19, 2012 The warning light on my car used to come on. Turns out it was because the car was trying to put down the active front spoiler but couldn't because I have an aftermarket bumper. I disabled it and its fine now. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 19, 2012 Author Share Posted December 19, 2012 are you sure this is not from the syvecs being fitted ? i know that some ecu's put out the warning light in the cetre as you realsticly no long have a stock ecu fitted at all but still have the auto ecu Yeah but none of the lights were on when I first bought the car with the syvecs fitted. The warning light on my car used to come on. Turns out it was because the car was trying to put down the active front spoiler but couldn't because I have an aftermarket bumper. I disabled it and its fine now. When I go over 60 the active spoiler light flashes as I havent got it fitted but this was never an issue before. It must have been bypassed some how. im pretty sure the main warning light will go off once the handbrake one goes off. Quote Link to comment Share on other sites More sharing options...
TuneR Posted December 20, 2012 Share Posted December 20, 2012 Ever changed brake calipers? I had both mine stay on after i rebuilt my calipers and forgot to tighten up one of the rears carrier bolts... Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 20, 2012 Author Share Posted December 20, 2012 Ever changed brake calipers? I had both mine stay on after i rebuilt my calipers and forgot to tighten up one of the rears carrier bolts... Nope! Havent touched anything but just not ran the car for 4 months. Quote Link to comment Share on other sites More sharing options...
Littler Posted December 20, 2012 Share Posted December 20, 2012 Yeah but none of the lights were on when I first bought the car with the syvecs fitted. When I go over 60 the active spoiler light flashes as I havent got it fitted but this was never an issue before. It must have been bypassed some how. im pretty sure the main warning light will go off once the handbrake one goes off. I think you have found the problem if the light comes on at 60 (as in on the switch unit) it means the active spoiler ECU is stil in place, so basically your car thinks the spoiler has a fault (as it's not there), the ECU is behind the head unit Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 20, 2012 Author Share Posted December 20, 2012 I think you have found the problem if the light comes on at 60 (as in on the switch unit) it means the active spoiler ECU is stil in place, so basically your car thinks the spoiler has a fault (as it's not there), the ECU is behind the head unit Ah ok then thanks mate So I just remove the ECU and the light should go out or do I need to put a resister somewhere? Quote Link to comment Share on other sites More sharing options...
Littler Posted December 20, 2012 Share Posted December 20, 2012 Just remove it and all will be good... hopefully lol For reference it's the one on top: Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 6, 2013 Author Share Posted March 6, 2013 Just remove it and all will be good... hopefully lol For reference it's the one on top: http://img.photobucket.com/albums/v415/Matt_H/DSCN0436.jpg Thanks Littler doing this now. Also for the 3 switches for seats, TC and spoiler can I leave these unplugged as none of this stock equipment is in place anymore? Quote Link to comment Share on other sites More sharing options...
Kaan W Posted March 19, 2013 Author Share Posted March 19, 2013 Removed this and no more warning lights come on when the active spoiler speed is achieved. Also I have found out that the handbrake warning lights are on from fitting the my led rear lights as the car senses there is a bulb out as the leds draw less current. So in short its all good Quote Link to comment Share on other sites More sharing options...
