Pulley Posted December 16, 2012 Share Posted December 16, 2012 all test fitted, heat wrapped and ready to go back on TT plenum and throttle body modified and cleaned ready to go on my NA-T, as a temporary get me going inlet as i havent finished my custom plenum Quote Link to comment Share on other sites More sharing options...
FOSTA Posted December 16, 2012 Share Posted December 16, 2012 Sweet mate! Are you welding the NA runners on that TT plenum? Quote Link to comment Share on other sites More sharing options...
Pulley Posted December 16, 2012 Author Share Posted December 16, 2012 Sweet mate! Are you welding the NA runners on that TT plenum? nope, ive modified the plenum , cut the centre two ports and re welded them, then slightly re positioned the outer ports and then polished n ported the whole setup, flows well into the na runners will almost be a shame to swap it out once ive finished my plenum im building, but it will get me going Quote Link to comment Share on other sites More sharing options...
buster Posted December 16, 2012 Share Posted December 16, 2012 Might just run I'm na setup till u finish your custom intake then give u some cash for yours Quote Link to comment Share on other sites More sharing options...
Pulley Posted December 16, 2012 Author Share Posted December 16, 2012 Might just run I'm na setup till u finish your custom intake then give u some cash for yours you can have it mate, once ive got setup and pull my finger out n finish my plenum, done the flow tests and cardboard mock up to make sure it will all fit ok, i will have to do a boot battery mod tho as the 100mm throttle body ends up pointing into the battery tray area Quote Link to comment Share on other sites More sharing options...
buster Posted December 16, 2012 Share Posted December 16, 2012 With the tt intake do we have to get the tt power steering reservoir ? Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted December 16, 2012 Share Posted December 16, 2012 this is what i wanna do to a greddy plenum! good work mate Quote Link to comment Share on other sites More sharing options...
Pulley Posted December 16, 2012 Author Share Posted December 16, 2012 With the tt intake do we have to get the tt power steering reservoir ? yeah, i have one you can have mate, but youll need to either make or buy the hose adaptor that bolts ontop the steering pump where the na reservoir goes, so you can run the remote tt reservoir Quote Link to comment Share on other sites More sharing options...
Pulley Posted December 16, 2012 Author Share Posted December 16, 2012 this is what i wanna do to a greddy plenum! good work mate you could weld up the flange face on the greddy plenum where needed then mill the new ports out and skim flat, hardest part is holding the plenum on the mill bed Quote Link to comment Share on other sites More sharing options...
buster Posted December 16, 2012 Share Posted December 16, 2012 You are far to helpful sir Quote Link to comment Share on other sites More sharing options...
Noz Posted December 16, 2012 Share Posted December 16, 2012 looking good mate. watching this. Quote Link to comment Share on other sites More sharing options...
