stainless steel braided brake lines questions
SupraP-Z
Hey all, a couple of questions. Up until now ive been relatively satisfied with my j spec brakes...but need to overhaul them and thought i might as well change to UK spec while im at it. If im going to change my brakes, i may as well upgrade to the stainless steel lines, but what difference do these make? Do you have to buy seperate ones for j-spec/UK spec? or are all the lines the same? Also where to buy a set of these? And how to install them? :D cheers
They are all the same for jspec and uk spec ive had a set of do luck ones sitting around since the summer but havent fitted them yet, they are just a streight swap for the old ones really easy to fit, mine or on the list of things too fit. one bolt on each caliper then screw off the other end attached too the hard lines, easy peasy
Goodridge do a kit for the mkiv or give CW a call or the traders on here.
Approx £60 or there abouts
Be a good idea to change your brake fluid at the same time as
well, Motul RBF600 or RBF660 is very good and you buy it in half litre bottles
Cheers dudes, i am planning to give the car a full service, going to be changing the brakes at the same time. Calipers (colour change too, as atm they are rusty metal) discs, pads, full fluid change and stainless steel lines. Am i correct in thinking i just need to transfer the existing 2 pot j-specs from the front to the back, and put the UK specs on the front? so basically my existing 1 pot j spec rears will be superseeded. Im new to all this...but learning fast!
Ah ok, so the UK 2 pots are different from the J spec 2 pots. Cheers Dunk
Yes mate, the uk calipers front and rear have opposed pistons that
squeeze the pads together
The j specs have a sliding carrier set up with the pistons being on
one side
Have a read through the pdf file on the brakes
If you look at page BR-28 you have the 2 piston sliding carrier type
known as j specs, on BR-48 is the 1 piston rear.
If you look on page BR-36 you have the 4 piston caliper known as
UK spec, this is the same as the rear UK spec but with just 2
opposed pistons on BR-54
BR.pdf
