charlton Posted December 15, 2012 Share Posted December 15, 2012 I'd like to lower my Supe more but not have to worry about speed bumps, are there any suspension setups similar to the systems on some high end cars such as Lambos etc? The ones where you can adjust the ride height/firmness from inside the car at the touch of a button, surely they are set up with springs etc and not air bags? Quote Link to comment Share on other sites More sharing options...
safcdixon Posted December 15, 2012 Share Posted December 15, 2012 Tein do an electric adjustable system for soft/hardness not sure if it raises and lowers though Quote Link to comment Share on other sites More sharing options...
Nic Posted December 15, 2012 Share Posted December 15, 2012 Top Secret do a kit that can raise and lower the ride height. Tein do the EDFC in car damper adjustment. http://www.tein.com/products/edfc.html Quote Link to comment Share on other sites More sharing options...
spikedjack Posted December 15, 2012 Share Posted December 15, 2012 Kw do the hls kits that look amazing if you can afford them Quote Link to comment Share on other sites More sharing options...
Kaan W Posted December 15, 2012 Share Posted December 15, 2012 Kw do the hls kits that look amazing if you can afford them I made a thread up on this a few weeks back, it says there product is suitable for KW coilovers and all stock applications which I persume is any aftermarket coilover also. I wouldnt have anything involving pneumatics tho. Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted December 15, 2012 Share Posted December 15, 2012 Height is adjusted manually on the Tein adjustables. As you say though the dampers can have an electrical Motor attached on each corner to adjust the stiffness! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted December 16, 2012 Share Posted December 16, 2012 Or you could just lower your car a sensible amount... Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 16, 2012 Share Posted December 16, 2012 Or you could just lower your car a sensible amount... Quote Link to comment Share on other sites More sharing options...
DaveR Posted December 16, 2012 Share Posted December 16, 2012 Or you could just lower your car a sensible amount... I think ride height on a road car will always be a compromise. Mine sure is! Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted December 16, 2012 Share Posted December 16, 2012 Get ready this will be expensive!!!!! Quote Link to comment Share on other sites More sharing options...
