electrical problem
golfvr6er
replace the fog light switch and when i put it back together the dash and rear and front side lights wouldn't turn off even when i took the keys out of the car and had everything off at the indicator stock. weird. so took the wires off the fog light switch. lights still on. check incase any fuses were blown. fuses all fine. disconected the indicator stock. lights still on.
head pickled. any ideas welcome?????
sorted. some butcher who fitted the fog light switch had taken the relay out and put the wire on one of the prawns and pushed it back into were it came. so it didnt have a fuse and when it shorted out with the lights on the switch in the relay stuck open and thats why the light wouldn't turn off. new relay and everything back to normal. the relay is in the drivers side kick panel above the fuse cover.
