tbourner Posted August 14, 2005 Share Posted August 14, 2005 I'm trying to run a Toshiba 20VL44G TV through a normal 15 pin VGA lead to an ATI Radeon 128Mb (9200 series) graphics card. But it seems to be using basic drivers and the screen is 'fuzzy'. Anyone got any sites for better drivers? Quote Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted August 14, 2005 Share Posted August 14, 2005 http://www.ati.com/ Quote Link to comment Share on other sites More sharing options...
Lucifer Posted August 15, 2005 Share Posted August 15, 2005 The screen will be fuzzy due to the scan lines on the TV. You can try increasign the refreshrate to 60 or 100 htz, but make sure your tv supports it. Quote Link to comment Share on other sites More sharing options...
tbourner Posted August 15, 2005 Author Share Posted August 15, 2005 Thanks westlife you joker!! I meant drivers specific for the TV, as the ATI drivers are just using the default drivers for the screen. Jay, it's an LCD TV so it doesn't have 'scan lines' as such, and can support 100Hz. Just would've thought the graphics card drivers would need to know what it is in order to give out more than the basic info (which they do to protect cheap nasty CRT monitors that can't handle it). Quote Link to comment Share on other sites More sharing options...
JustGav Posted August 15, 2005 Share Posted August 15, 2005 Try the omega drivers, on google just search for 'ati omega'... however I doubt you will get a good picture on the tv, after all the res is a lot lower, and the refresh rate.. Does the TV support a 15pin VGA connector directly?? also note that LCD's are fuzzy if they aren't running at native resolution due to the way it does pixel interpolation.. Gav Quote Link to comment Share on other sites More sharing options...
tbourner Posted August 15, 2005 Author Share Posted August 15, 2005 Yeah it's got a 15 pin din cable on it, and it's supposed to be designed with graphics card use in mind, but it belongs to a bloke who works in cash converters so I doubt he managed to get hold of any official documentation or drivers with it!!! Quote Link to comment Share on other sites More sharing options...
Daston Posted August 17, 2005 Share Posted August 17, 2005 go to http://www.aoaforums.com and ask they will help you out in a flash (the best thing is they even use the same forum engine as here!) Quote Link to comment Share on other sites More sharing options...
carl0s Posted August 19, 2005 Share Posted August 19, 2005 you should start by finding out what the LCD TV's physical resolution is. Unfortunately they are usually dreadfully low. Quote Link to comment Share on other sites More sharing options...
carl0s Posted August 19, 2005 Share Posted August 19, 2005 apparently it should be run at 800x600. not too shabby for an LCD TV. still way off what a 20" LCD Monitor would be (1280x1024?) Quote Link to comment Share on other sites More sharing options...
tbourner Posted August 20, 2005 Author Share Posted August 20, 2005 Apparently according to aoaforums that TV doesn't have a VGA output, but his TV definitely does - so it may be the wrong part number - maybe a better version. Quote Link to comment Share on other sites More sharing options...
carl0s Posted August 20, 2005 Share Posted August 20, 2005 btw, the only DIN-type connector that's anything like relevant would be the 4-pin s-video mini-din. Monitors use a 15pin d-sub. Can your mate count? Quote Link to comment Share on other sites More sharing options...
carl0s Posted August 20, 2005 Share Posted August 20, 2005 regardless, he'll get the best picture if he sets his desktop & games to 800x600 Quote Link to comment Share on other sites More sharing options...
tbourner Posted August 20, 2005 Author Share Posted August 20, 2005 Yeah it has a 15 pin VGA lead, well just a 15 pin VGA male terminal on the TV, and a female to female 15 pin VGA lead going to the graphics card. Quote Link to comment Share on other sites More sharing options...
Dash Rendar Posted August 21, 2005 Share Posted August 21, 2005 I agree with Carl0s. LCD screens have a 'native' resolution. If your graphics card is set to anything other than this resolution, the display device has to interpolate the image data which makes the screen go fuzzy. Quote Link to comment Share on other sites More sharing options...
