Mugello Posted December 13, 2012 Share Posted December 13, 2012 Has anyone got any close up pictures of the greddy inlet manifold fitted & plumbed in ? Im interested in the areas i have circled on the below picture. Can anyone help ? http://img831.imageshack.us/img831/8315/41054133.jpg Cheers, Moo. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted December 13, 2012 Share Posted December 13, 2012 On the right the plug is the stock Intake air Temp sensor, the vacuum/boost point can be anything you want. The centre is a random vacuum /boost take off. On the left, (From the right) Idle air control valve take-off, Brake master vacuum booster take-off, and the oter two are whatever you want them to be. I have never seen them used personally, no need. Quote Link to comment Share on other sites More sharing options...
Mugello Posted December 14, 2012 Author Share Posted December 14, 2012 Thank you ! So... -Stock Intake air Temp sensor = Next to number 2 on that above picture ? -Vacuum/boost point = Number 2 on that above picture ? -The centre is a random vacuum /boost take off. -Idle air control valve take off = Number 3. ? -Idle air control valve take off = Number 5. ? -Number 4's are whatever needed. So, typically a bpu supra running this inlet would use numbers 5,3,2 and one of the vac points? Quote Link to comment Share on other sites More sharing options...
Lee P Posted December 15, 2012 Share Posted December 15, 2012 If its a stock bpu car the lower vac line is used as well. Goes to the valve for the charcole canister Use 1 or the one close to it for map sensor and fpr Use 2 for cam breather and intake temp sensor Use 3 for idle control valve Use 4 for extra things like boost gauge ect but I usually blank them The one at the front you havnt circled goes to the power steering The lower one is for charcole canister valve. Quote Link to comment Share on other sites More sharing options...
Mugello Posted December 15, 2012 Author Share Posted December 15, 2012 (edited) Thanks Lee !! Very helpful information. Whats number 5, Brake master vacuum booster take-off? (I think thats what Turtleshead said going from the right side) Edited December 15, 2012 by Mugello (see edit history) Quote Link to comment Share on other sites More sharing options...
