john88 Posted December 13, 2012 Share Posted December 13, 2012 (edited) Ok Guys n girls, Before the car goes in for painting I'm thinking of fitting a harness bar. Now my question is does anyone use one? (that isn't part of a roll cage) and where have you fit it? Now I'm not going to be having a back seat as I'm planning a small audio install in it's place and obviously shoulder straps should be fit between 0 and 45 degrees downwards angle to the eyelets in the seat. I have used the old bolt in / weld in eyelets with harnesses in the past on other cars but I feel that due to the shape of the rear that I wouldn't be able to fit these in line. So what can people suggest? And also does any one make one specifically for the supra? Edited December 13, 2012 by john88 can't type... (see edit history) Quote Link to comment Share on other sites More sharing options...
Jamesy Posted December 13, 2012 Share Posted December 13, 2012 if you arent using back seats just bolt them to the rear seat belt points. Quote Link to comment Share on other sites More sharing options...
charlton Posted December 13, 2012 Share Posted December 13, 2012 I am going to fit mine to my strut brace when i get my buckets & harnesses in Quote Link to comment Share on other sites More sharing options...
john88 Posted December 13, 2012 Author Share Posted December 13, 2012 That was quick Jamesy! As I said I'm planning on doing a small audio build to replace the back seat, but also when I looked at the rear belt points they do look a bit more than 45 degrees. As I've already lost one supra to the track and plan to do more track days I'd rather stay within the limits of what is known to be 'safe'. I am going to fit mine to my strut brace when i get my buckets & harnesses in I did think about this, maybe it's just me but it screams 'your gunna regret this' Quote Link to comment Share on other sites More sharing options...
Wez Posted December 13, 2012 Share Posted December 13, 2012 I wouldn't use harnesses unless you have a full cage, do you really want to be fixed tight into position if you rolled and the roof caved in? Quote Link to comment Share on other sites More sharing options...
Jamesy Posted December 13, 2012 Share Posted December 13, 2012 I wouldn't use harnesses unless you have a full cage, do you really want to be fixed tight into position if you rolled and the roof caved in? Hopefully as he does lots of track days a cage is on the do-do list if its not already got one Quote Link to comment Share on other sites More sharing options...
Wez Posted December 13, 2012 Share Posted December 13, 2012 Hopefully as he does lots of track days a cage is on the do-do list if its not already got one If thats the case, weld some hoops onto the rear cross bar and feed the straps through Quote Link to comment Share on other sites More sharing options...
john88 Posted December 13, 2012 Author Share Posted December 13, 2012 At the moment I don't have a cage, as the car is a daily but used on the track when I get chance. I've always seen it as the cons outweigh the pro's, like not wearing a helmet on the road and should something happen its something else to bang my head on..... but as they say no sense, no feeling I wouldn't use harnesses unless you have a full cage, do you really want to be fixed tight into position if you rolled and the roof caved in? Again it's pros and cons really, as you have said which is a very good point. No you don't really want to be strapped in tight with a caved in roof but, then again should something happen... again... I don't really want to smash my helmet against anything in close proximity like windows and steering wheels as you get quite a headache Quote Link to comment Share on other sites More sharing options...
Guest Nicholas Posted December 13, 2012 Share Posted December 13, 2012 Harnesses without a cage = Quote Link to comment Share on other sites More sharing options...
