Upgrades for maximum traction?
Kaan W
Before i had a Geo check done on mine i was only using about 2" of the inside of the rear tyres (previous owner fitted coilovers himself) So its good to see everyone saying how important the Geo setup is. No use having expensive tyres if you're not actually having them making propper contact with the ground.
Yeah that does make sense now people have mentioned it. Im getting quite alot of arch rub at the moment tho so the rear definately needs to come up a couple of cm if I run the rear on a softer setting. Looking from the back of the car the wheels have quite a bit of negative camber which gets worse as the suspension compresses I believe. This could be what needs adjusting.
