Boost fuel-cut and turbo timer controller!
shaz2010
Here is his response ;
Hi,
Thank you for your message,
This unit has to be hard wired into the ignition harness which is a very easy as ther are on 2-3 wires and the Fuel Cut defender is only 2 wires which is joined into the AFM Sensor wire on the ECU harness to intercept the signal and alter it to stop fuel cut.
The Installion is very straight forward and would be ideal for your BPU I use one myself on my 1JZ Single turbo converted Soarer with amazing results. There are not boost controllers on the market that come with a plug in loom and all have to be hard wired.
If I can be of any further help please feel free to contact me.
Kind Regards
Jason
