lexus IS200 wheel fitment on Supra
Guest pedro5189
Guest pedro5189
I have looked high and low to find some wheels to use through the winter. Obviously not wanting to spend a great deal on winter wheels I was wondering if anyone has tried the 7x17" et50 variant of these from the IS200. It should be pointed out that they will need to clear my jap spec 4 pot brakes.
If these wont fit does anyone know of any other 17" oem Lexus wheels that will clear the brakes?
Guest pedro5189
Thanks guys,
I was hoping to have a set suited to using 225s allround with dedicated winter tyres so fear they will not fit a 9.5j rim
J Specs are two pot mate. UK Spec are 4 pot.;)
Not strictly true, J-spec Supras were factory fitted with the larger 4pot/2pot brakes and the smaller 2pot/1pot brakes depending on the year and model. In fact there were more J-spec Supra made with the larger brakes than UK spec Supras.
The is200 wheels are too narrow for the Supra.
The standard Supra wheels have staggered wheel/tyre widths.
Front - 17x8J +50 - 235/45ZR-17
Rear - 17x9.5J +50 - 255/45ZR-17
No, I knew that Nic. It's just that they are always referred to as UK spec.
My jspec car came with the 4pot2pot brakes.:)
Is it not 40 profile in the rear Nic ? or am I mistaken?
...If these won't fit does anyone know of any other 17" oem Lexus wheels that will clear the brakes?
Don't know about the IS wheels. It might be worth checking on Club Lexus or MyIS - people sometimes fit Supra 4-piston calipers to the IS200/300.
Late LS400 wheels might be OK - from '94 (UCF20 model) they had 4-piston front calipers.
225s would be a bit narrow for 9.5 inch wheels. 235s would probably be the limit.
Edited by garethr (see edit history)
Yup
Nic's slacking :)
A narrower tyre is better in snow as it cuts through it giving
you grip rather than sliding around on top of it ;)
I have a set of o/e 17's with tyres caps and o/e nuts for sale :)
Guest pedro5189
Thank you
Looks like it may be a little simpler if I find some OEM 17" supra wheels then as their are a few sets about
Dnk - PM sent
