Found something cool about my car
scott87
I was doing some searches online about my car, mot checks etc etc and 1 found that it needed a lot of work at one point:
Nearside Headlamp insecure (1.7.3)
Nearside Front Lower Suspension arm has excessive play in a ball joint (2.4.G.2)
Nearside Rear michelin 235-45zr17 Tyre tread depth below requirements of 1.6mm (4.1.E.1)
Front brake disc worn, pitted or scored, but not seriously weakened (3.5.1i)
Rear brake disc slightly pitted (3.5.1h)
Front Brake pad(s) wearing thin (3.5.1g)
Rear Brake pad(s) wearing thin (3.5.1g)
Rear Sub-frame corroded but not seriously weakened (2.4.G.1)
Exhaust has part of the system slightly deteriorated (7.1.1a)
Nearside Front Brake hose slightly deteriorated (3.6.B.4d)
Offside Front Brake hose slightly deteriorated (3.6.B.4d)
Offside Rear 2mm Tyre worn close to the legal limit (4.1.E.1)
Offside Rear Upper Suspension arm has slight play in a pin/bush (2.4.G.2)
Corrosion on both outer sills
Age cracking on o/s/f tyre
Wear on edge of n/s/f tyre
But not only this was a uber late registration. In fact it was registered on the last day of Decemeber in 1995 almost making it a 1996 reg car. Just thought that was quite nice to find i gained some months on her life!
