barneybrendan Posted December 1, 2012 Share Posted December 1, 2012 I have a 1999 mercedes v class that im changing from auto to manual.Most things look easy enough apart from the ecu side of things.Anybody have any ideas if the manual ecu will work right away,it has the same plugs.Also what would i do with the auto gearbox ecu. Quote Link to comment Share on other sites More sharing options...
David P Posted December 1, 2012 Share Posted December 1, 2012 It might be easier to leave the auto ECU in and fool it to function without error codes? Maybe you'll just have to suck it and see. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 1, 2012 Author Share Posted December 1, 2012 how would i do that though.Do you mean the auto gearbox ecu or the main engine ecu. Quote Link to comment Share on other sites More sharing options...
David P Posted December 1, 2012 Share Posted December 1, 2012 Try the manual one first, if it doesn't do as it's told then try the auto ECU and hard wire out some of the auto functions and fit a resistor here and there to fool others. Quote Link to comment Share on other sites More sharing options...
barneybrendan Posted December 1, 2012 Author Share Posted December 1, 2012 Try the manual one first, if it doesn't do as it's told then try the auto ECU and hard wire out some of the auto functions and fit a resistor here and there to fool others. what do i do with the gearbox ecu.do i just leave it connected Quote Link to comment Share on other sites More sharing options...
David P Posted December 1, 2012 Share Posted December 1, 2012 The two ECU's will be 'talking' to each other and sensors various and the lights on the dash, you'll need to mix and match from my previous comments then suck it and see and work your way through it. If you don't have the Workshop Manual for both systems to study, you won't stand a chance. Quote Link to comment Share on other sites More sharing options...
