Measure Oil Pressure
Jellybean
•The oil sender does not have an "OUTPUT" . its a variable ground
•In an Auto setup (More pressure= less resistance, makes the gauge go up),
•More pressure= less resistance
•Less pressure= more resistance
What I can do:
•Remove the wire from the sending unit. The gauge reads full scale.
•Short the wire to ground and it reads "0".
Question
With the Gauge and Sender off the car ,
How do you trick an oil pressure sender into measuring pressure?, so I can get the variable OMH reading on the Multimeter or is the only way by putting it on the car with the Engine running?
