Jellybean Posted November 30, 2012 Share Posted November 30, 2012 •The oil sender does not have an "OUTPUT" . its a variable ground •In an Auto setup (More pressure= less resistance, makes the gauge go up), •More pressure= less resistance •Less pressure= more resistance What I can do: •Remove the wire from the sending unit. The gauge reads full scale. •Short the wire to ground and it reads "0". Question With the Gauge and Sender off the car , How do you trick an oil pressure sender into measuring pressure?, so I can get the variable OMH reading on the Multimeter or is the only way by putting it on the car with the Engine running? Quote Link to comment Share on other sites More sharing options...
jjs_82 Posted November 30, 2012 Share Posted November 30, 2012 You can give me a call if you need help. Quote Link to comment Share on other sites More sharing options...
