Calipers - Wanted - Rebuild kit, New calipers or used.
pbryant_knight
HI all,
Ive decided that i'm going to try to sort the calipers in my first effort to stop the wheel noise from the front passenger side. I know one is sticking slightly anyway so they'd need doing eventually. Had them freed off when i had the new discs and pads put on but don't think that did much.
Was looking at rebuild kits on eBay but not sure what i would need. all the kits look different. My car is a 1996 jap N/A, can anyone post up a link of a kit on ebay that will do the job?
Failing that, does anyone have some standard jap calipers that have maybe already been refurbed? Maybe after you've done a UK or big brake upgrade?
Cheers
Peter
Give CW a call, he sells the seal kits and pistons for both types of mkiv caliper.
If you have the smaller brakes, 2 piston front 1 piston rear the problem could be
wear and corrosion on the sliding pin part in which case if their very bad they might
not be worth refurbing
  • 2 weeks later...
