Josh42 Posted November 27, 2012 Share Posted November 27, 2012 Whilst at 70 on the motorway, I noticed steam from the bonnet and the temperature shoot up rapidly. Upon opening the bonnet, there was massive pressure and steam coming from the expansion tank and the back right of the bulkhead(passenger side) Heaters were stone cold and carpet was dry. Any ideas? Quote Link to comment Share on other sites More sharing options...
Alex Posted November 27, 2012 Share Posted November 27, 2012 Yes - replace your radiator cap. It's not holding pressure and letting the coolant escape. Good time to do a full coolant flush too. Quote Link to comment Share on other sites More sharing options...
Guest BradD Posted November 27, 2012 Share Posted November 27, 2012 check the crank pulley .If it's knackered,it will cause the engine to overheat. Quote Link to comment Share on other sites More sharing options...
ballsdeep Posted November 27, 2012 Share Posted November 27, 2012 I Replaced the thermostat and rad cap when it happened to me! Job done Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 9, 2012 Author Share Posted December 9, 2012 Right, removed the thermostat, and topped up the coolant. Had a sniffer test done on the car and it came back clear. There's no milky oil/coolant mixture anywhere. Car still overheats and there's a hose that goes into the back of the block that's pissing out steam when overheating. The heaters will not get hot however, the carpet is dry. There also appears to be a leak at the back of the water pump somewhere. Anybody got any ideas what's causing my issue? I think it may be water pump? Quote Link to comment Share on other sites More sharing options...
buster Posted December 9, 2012 Share Posted December 9, 2012 Water pump sounds likely not getting the water round the engine and there for overheating Quote Link to comment Share on other sites More sharing options...
Guest BradD Posted December 9, 2012 Share Posted December 9, 2012 Tought you sorted this out by now mate.If you need a water pump to test it out ,i have one.pm me. Quote Link to comment Share on other sites More sharing options...
Steve Paine Posted December 9, 2012 Share Posted December 9, 2012 Have you changed your fluids lately. Heater not working sounds like an air block ( best case scenario). I think there is a thread on here somewhere about getting it all through! Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 9, 2012 Author Share Posted December 9, 2012 I hadn't replaced the fluids recently actually. Unfortunately not Brad, ill send you a PM shortly mate. It still doesn't explain the leak at the hose at the rear f the block or the leak around the rear of the water pump...:/ Really racking my brains on this one! Quote Link to comment Share on other sites More sharing options...
buster Posted December 9, 2012 Share Posted December 9, 2012 is it the hose that go's into the head right at the back ? could just be the easiest place to let the steam out Quote Link to comment Share on other sites More sharing options...
Terminator Posted December 9, 2012 Share Posted December 9, 2012 (edited) Possibly the blades on you water pump have broken making the pump as good as useless. Not sure but thought there were two types one with plastic blades that go brittle and another with metal blades. If you are getting steam out the back of the block hoses you have some serious hot spots, I would get it sorted before you over heat too far. Have you done what Alex suggested in post 2. Edited December 9, 2012 by Terminator (see edit history) Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 9, 2012 Author Share Posted December 9, 2012 Replaced the rad cap and going to flush the coolant and bleed the system. Cheers guys! Is the waterpump a Cambelt off job? Quote Link to comment Share on other sites More sharing options...
buster Posted December 9, 2012 Share Posted December 9, 2012 might be able too might give u more room to take off tho looks like cam cover will need removing Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 10, 2012 Share Posted December 10, 2012 Right, removed the thermostat, and topped up the coolant. Had a sniffer test done on the car and it came back clear. There's no milky oil/coolant mixture anywhere. Car still overheats and there's a hose that goes into the back of the block that's pissing out steam when overheating. The heaters will not get hot however, the carpet is dry. There also appears to be a leak at the back of the water pump somewhere. Anybody got any ideas what's causing my issue? I think it may be water pump? I'd say this is part of your problem Quote Link to comment Share on other sites More sharing options...
Alex Posted December 10, 2012 Share Posted December 10, 2012 Bypass the heater matrix and see if it still can't flow. (Join the hoses that go in and out of it). Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 10, 2012 Share Posted December 10, 2012 To check the matrix isn't blocked couldn't you just put a hose pipe onto the inlet of the matrix and see if it flows out of the outlet ? Quote Link to comment Share on other sites More sharing options...
Alex Posted December 10, 2012 Share Posted December 10, 2012 To check the matrix isn't blocked couldn't you just put a hose pipe onto the inlet of the matrix and see if it flows out of the outlet ? Yep, true enough....you can even fire it the other way to try to unblock it. Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 10, 2012 Share Posted December 10, 2012 Yep, true enough....you can even fire it the other way to try to unblock it. I recall that's been known to finish off a gammy matrix, so be prepared for the replacement job if you try this Quote Link to comment Share on other sites More sharing options...
Josh42 Posted December 15, 2012 Author Share Posted December 15, 2012 Found it! Back of the waterpump is pissing water out. Anyone know how much for an OEM waterpump with gaskets etc? Quote Link to comment Share on other sites More sharing options...
bignum Posted December 15, 2012 Share Posted December 15, 2012 Found it! Back of the waterpump is pissing water out. Anyone know how much for an OEM waterpump with gaskets etc? http://www.ebay.co.uk/itm/FIRSTLINE-WATER-PUMP-RC231302P-TO-FIT-TOYOTA-SUPRA-3-0-93-96-OE-QUALITY-/300748176443?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ASupra&hash=item4605fcfc3b Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted December 15, 2012 Share Posted December 15, 2012 I got one mate that i removed from mine and replaced with a new one. Pm if interested Quote Link to comment Share on other sites More sharing options...
Guest BradD Posted December 15, 2012 Share Posted December 15, 2012 have one as good as new.Pm if you're interested Quote Link to comment Share on other sites More sharing options...
bignum Posted December 15, 2012 Share Posted December 15, 2012 Cambelt off job aswell, happy days. Quote Link to comment Share on other sites More sharing options...
Shane Posted December 16, 2012 Share Posted December 16, 2012 Almost certainly will not be the actual pump. It will be a £1 core plug that sits in the back of the rear housing. Such a common problem and I have never understood why only that core plug fails so often and if you pop any of the others out, they will most likely appear mint. I have a brand new one in my toolbox if you want it. Quote Link to comment Share on other sites More sharing options...
Dnk Posted December 16, 2012 Share Posted December 16, 2012 Found it! Back of the waterpump is pissing water out. Anyone know how much for an OEM waterpump with gaskets etc? What about the steam at the back of the engine ? Quote Link to comment Share on other sites More sharing options...
