JayRZ93 Posted November 27, 2012 Share Posted November 27, 2012 Has anyone installed one to their stock twins setup? Would the install be the same on a JDM Supra TT such as mine? After installed, how did you setup the 2 different pre-set boost settings? Thank you for the help guy's. Quote Link to comment Share on other sites More sharing options...
TubbyTwo Posted November 27, 2012 Share Posted November 27, 2012 Have you got the manual for it? Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted November 27, 2012 Author Share Posted November 27, 2012 Just the manual how to set it up once it is installed. Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted January 17, 2013 Author Share Posted January 17, 2013 Anyone know of a pictured link how to install the HKS EVC 5 ebc to stock twins? Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted January 20, 2013 Author Share Posted January 20, 2013 Anyone?? Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted January 20, 2013 Share Posted January 20, 2013 I think I have a link matey, I'll dig it out when I pop the pc on later Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted January 20, 2013 Author Share Posted January 20, 2013 I think I have a link matey, I'll dig it out when I pop the pc on later Thank you sir. Quote Link to comment Share on other sites More sharing options...
letmeshowyou Posted January 20, 2013 Share Posted January 20, 2013 Hey. Looks like it wasn't the EVC5, but there are a couple of articles on ebc installation here: http://mkiv.com/techarticles/index.html#bpu Any help? One of these is the one I originally learnt from when I installed a profec b2 on my first TT. Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted February 9, 2013 Author Share Posted February 9, 2013 Can anyone supply pic's? Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted March 12, 2013 Author Share Posted March 12, 2013 Can anyone send me under the hood pics of where to plumb in the hoses from there HKS EVC 5 into a JDM Supra TT? [email protected] Really don't want to screw this up. Thanks! Quote Link to comment Share on other sites More sharing options...
Supranature Posted March 12, 2013 Share Posted March 12, 2013 Have a GOOD read of this http://www.max-boost.co.uk/max-boost/supra/turbo.htm Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 12, 2013 Share Posted March 12, 2013 its at the front just follow the guide in the link letmeshowyou posted .... simple Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 12, 2013 Share Posted March 12, 2013 Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted March 12, 2013 Author Share Posted March 12, 2013 [ATTACH=CONFIG]165685[/ATTACH] Thank you get much for diagram sir, very easy to read. Although my evc 5 solenoid has 3 nipples, I only see 2 beeing used in your diagram. Quote Link to comment Share on other sites More sharing options...
ashbuster Posted March 12, 2013 Share Posted March 12, 2013 (edited) it might be a similar solenoid to mine and only 2 are used and one is a bleeder, double check tho to be sure or maybe one goes to your boost controller or gauge had a little look for you and it looks like it goes to where you normally tap into to plumb a boost gauge in the HKS solenoid is marked B = 1 is another reference for the boost controller from the plenum. I = 2 which goes to pressure reference source/turbo. O = 3 which goes to the actuator. there are two ports on this, one of which must be blocked off. any probs look here mate http://www.mkivsupra.net/vbb/showthread.php?114088-Help-Installing-HKS-EVC-5/page3 Edited March 12, 2013 by ashbuster (see edit history) Quote Link to comment Share on other sites More sharing options...
JayRZ93 Posted March 12, 2013 Author Share Posted March 12, 2013 it might be a similar solenoid to mine and only 2 are used and one is a bleeder, double check tho to be sure or maybe one goes to your boost controller or gauge [ATTACH=CONFIG]165764[/ATTACH] had a little look for you and it looks like it goes to where you normally tap into to plumb a boost gauge in [ATTACH=CONFIG]165766[/ATTACH] the HKS solenoid is marked B = 1 which goes to the plenum. I = 2 which goes to pressure reference source/turbo. O = 3 which goes to the actuator. The solenoid in your last diagram u supplied is the same as mine. Has 3 nipples. Do you know how to plumb this into a 2jz gte? Quote Link to comment Share on other sites More sharing options...
