Brazil Posted November 26, 2012 Share Posted November 26, 2012 (edited) Gents, What clutch & flywheel set up would you recommend me for my power goal of 750 lbs/ft Max? How many of you guys are running a lighten flywheel? FYI: When I changed my clutch about 10k miles ago I did not change my flywheel; So I am thinking it would be a good idea to get a new one this time? If you have a clutch for sale post here too as I may be interested. Edited November 26, 2012 by Brazil (see edit history) Link to comment Share on other sites More sharing options...
johnny g Posted November 26, 2012 Share Posted November 26, 2012 It's more torque that you'll have to worry about, than BHP. I'd see what Dane at DC Automotive can do, as he's done one specifically for Hodge. Link to comment Share on other sites More sharing options...
Brazil Posted November 26, 2012 Author Share Posted November 26, 2012 It's more torque that you'll have to worry about, than BHP. I'd see what Dane at DC Automotive can do, as he's done one specifically for Hodge. What are your thoughts on lighten flywheels? Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 26, 2012 Share Posted November 26, 2012 Given the diameter of the bellhousing and therefore the constraints of a stock diameter flywheel you will have to use a multi plate clutch, with attendent rattling when disengaged, and the gear train noise from losing the dual mass flywheel (which will NOT stand that sort of torque figure. Most multi plate clutches are simply dreadful in a road car environment, but the Giken ones are probably the best made and the most civilised I have tried. I have a triple plate Giken in my Skyline (which is NOTHING like that sort of torque figure), and the wife can drive it without even noticing there's anything odd about the clutch at all. (There again she doesn't notice punctures, oil warning lights or fuel gauges on empty, so not the best recommendation, but you get my drift....). If it were a wide and tall US V8 with the room for a whopping diameter flywheel you could use a single plate organic clutch with centrifugal bob weights and it would take the torque and be light and totally civilised, but the smallish flywheel makes things trickier and more expensive. I have a big power single turbo Supra here right now. I am *~@*5$ off with it already, just moving it about the yard. Won't go into gear properly and heavy as hell, awful thing. Giken have given me FAR less trouble than any other clutches, over the years, proper race stuff apart. Link to comment Share on other sites More sharing options...
Brazil Posted November 27, 2012 Author Share Posted November 27, 2012 Given the diameter of the bellhousing and therefore the constraints of a stock diameter flywheel you will have to use a multi plate clutch, with attendent rattling when disengaged, and the gear train noise from losing the dual mass flywheel (which will NOT stand that sort of torque figure. Most multi plate clutches are simply dreadful in a road car environment, but the Giken ones are probably the best made and the most civilised I have tried. I have a triple plate Giken in my Skyline (which is NOTHING like that sort of torque figure), and the wife can drive it without even noticing there's anything odd about the clutch at all. (There again she doesn't notice punctures, oil warning lights or fuel gauges on empty, so not the best recommendation, but you get my drift....). If it were a wide and tall US V8 with the room for a whopping diameter flywheel you could use a single plate organic clutch with centrifugal bob weights and it would take the torque and be light and totally civilised, but the smallish flywheel makes things trickier and more expensive. I have a big power single turbo Supra here right now. I am *~@*5$ off with it already, just moving it about the yard. Won't go into gear properly and heavy as hell, awful thing. Giken have given me FAR less trouble than any other clutches, over the years, proper race stuff apart. Thanks for your input; by any chance you have a Gilken or lighten flywheel for sale? Link to comment Share on other sites More sharing options...
Callaway Motorsport Posted November 27, 2012 Share Posted November 27, 2012 Hi mate, the clutch we did for john was due to him NOT wanting a twin or triple plate clutch. To be honest i would stick to what chris says, as we are distributor for OS Giken and we have never had problems with them Their consistency is always flawless. And for the performance they are reasonably priced (unlike paying over 2K for an RPS). I have sent you a PM. Link to comment Share on other sites More sharing options...
a98pmalcolm Posted November 27, 2012 Share Posted November 27, 2012 Rps ftw Link to comment Share on other sites More sharing options...
Jellybean Posted November 29, 2012 Share Posted November 29, 2012 Hi mate, the clutch we did for john was due to him NOT wanting a twin or triple plate clutch. To be honest i would stick to what chris says, as we are distributor for OS Giken and we have never had problems with them Their consistency is always flawless. And for the performance they are reasonably priced (unlike paying over 2K for an RPS). I have sent you a PM. Hey Can you send me a quote for a OsGiken for a 1997 Skyline R33 GTST delivered to Dublin Ireland ; she will be running around 550 hp and similar Torque thanks Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 29, 2012 Share Posted November 29, 2012 I have a used twin plate Giken with flywheel for a GTS-t in good condition. Only swapped out for a triple when I built my new engine. Plus, the good thing about Giken is rebuild parts, in fact ALL spare parts are easily available. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 29, 2012 Share Posted November 29, 2012 Thanks for your input; by any chance you have a Gilken or lighten flywheel for sale? Triple plate Giken with movement change over kit (to convert from pull to push clutch is about 2k plus VAT All dual and triple plate Gikens come with a new lightweight flywheel as standard, where required. Link to comment Share on other sites More sharing options...
Jellybean Posted November 29, 2012 Share Posted November 29, 2012 I have a used twin plate Giken with flywheel for a GTS-t in good condition. Only swapped out for a triple when I built my new engine. Plus, the good thing about Giken is rebuild parts, in fact ALL spare parts are easily available. Thanks Chris, do you have a Price in mind; I will forward onto Simon A twin should handle his power? Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 29, 2012 Share Posted November 29, 2012 Let me pull the box down and check the wear on it, it should be mint, it had sod all miles on it and never, ever, did a hard standing start. Link to comment Share on other sites More sharing options...
Jellybean Posted November 29, 2012 Share Posted November 29, 2012 Let me pull the box down and check the wear on it, it should be mint, it had sod all miles on it and never, ever, did a hard standing start. Thanks, do you know what they are Power it is rated at; I see the OsGiken website has a few twin clutches ; do you know the model? Link to comment Share on other sites More sharing options...
