Will my clutch make a dyno session on new setup?
Brazil
Hi,
I am currently running a South bend stage 2 clutch with OEM flywheel which is rated at 575 lbs/ft.
The clutch was fitted 3 years ago and done +/- 10k miles; What I would like to know is if my clutch will be able to cope with my HKS TO4Z soon to be fitted turbo kit along with supporting mods to take it to 700 bhp.
Only thing to consider, if you decide not to change the clutch and it starts slipping when mapping it will be a wasted trip for Ryan and you will end up paying twice.
That is what I am thinking...! Not worth taking the risk...!
If I fit a new Clutch and Flywheel I will need to drive a certain mileage to bed it in correct? I guess I can do that from a base map?
