Swampy442 Posted November 23, 2012 Share Posted November 23, 2012 (edited) Is it an MOT failure to have the pad wear warning light on a la ABS, or just an advisory? Edited November 23, 2012 by Swampy442 (see edit history) Quote Link to comment Share on other sites More sharing options...
adam1983 Posted November 23, 2012 Share Posted November 23, 2012 I think anything brake related is taken pretty seriously mate. Could be wrong but the wife's car failed due to brakes Quote Link to comment Share on other sites More sharing options...
ronttuk Posted November 23, 2012 Share Posted November 23, 2012 its a fail Quote Link to comment Share on other sites More sharing options...
garethr Posted November 23, 2012 Share Posted November 23, 2012 (edited) http://www.motinfo.gov.uk/htdocs/index.htm There's a visual check on pad wear ("a brake lining or pad insecure or less than 1.5 mm thick at any point"), but I can't see anything about the pad wear warning lamp, only the ABS and brake fluid level lamps. EDIT: Anyway, doesn't it stay off if you disconnect the wires from the pads? Edited November 23, 2012 by garethr (see edit history) Quote Link to comment Share on other sites More sharing options...
Tyson Posted November 23, 2012 Share Posted November 23, 2012 Take the bulb out Quote Link to comment Share on other sites More sharing options...
jonc Posted November 23, 2012 Share Posted November 23, 2012 I thought from April 2012 any warning light on the dash board was a failing item? As far as I am aware removing the bulb does not work because the testers look for the bulbs to illuminate when they turn the ignition on. Saying that just checked VOSA and their changes state:- Other dashboard warning lights For cars fitted with ESC (electronic stability control) the warning light should come on and then extinguish after a few seconds. If it stays on to warn of a fault, the car will fail. This also applies to warning lights for cars fitted with electric power steering, brake fluid warning lights, tyre pressure monitors, air bags lights and seat belt pre-tensioner warnings. Power steering fluid level & electric steering malfunction For cars with hydraulic power steering, the reservoir will be check to make sure the fluid level is above the minimum mark. (Cars where the level is not visible without removing the cap will not be checked.) For cars with electric power steering, the malfunction light on the dashboard should come on and then extinguish after the car is started. The wear down light does not get a mention here Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 23, 2012 Author Share Posted November 23, 2012 Thanks for the replies gents http://www.motinfo.gov.uk/htdocs/index.htm There's a visual check on pad wear ("a brake lining or pad insecure or less than 1.5 mm thick at any point"), but I can't see anything about the pad wear warning lamp, only the ABS and brake fluid level lamps. EDIT: Anyway, doesn't it stay off if you disconnect the wires from the pads? The pads are all brand new, replaced by my own fair hands. But the indicator cables have been on the car for a long time, hanging free, probably since before the last pad rotation. Could take the bulb out but Im sure any tester will look at the brakes, see some nasty looking wires hanging about and know something was afoot lol. I knew about the ABS, just have to see how particular the tester is. Quote Link to comment Share on other sites More sharing options...
Benjy Posted November 24, 2012 Share Posted November 24, 2012 It's a pass and advise atm. Most of the stuff that was coming into the test in April still hasn't. The whole MOT system these days is a crock of s***! Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted November 24, 2012 Author Share Posted November 24, 2012 Just for your info, its not an MOT advisory, they made no mention of it Thanks for your help. Quote Link to comment Share on other sites More sharing options...
Benjy Posted November 24, 2012 Share Posted November 24, 2012 I'd do a manual advisory if it came in for me to test and there was no mention of it anywhere else. Quote Link to comment Share on other sites More sharing options...
