high pitched whining noise on startup....
hazza
on initial start up it will whine, and when i pull away it will get more high pitched then when it changes to second it goes...
when i accelerate in N, its there but disapears when revs get to around 2k, it sounds like its coming from down the front maybe the aux pulley?
have heard it maybe the crank pulley poss? if it turns out what you guys reply with its the crank pulley IL do the tippex test, but thought id get some advice from the guys in the know first :)
just wondering if anyone else has had this problem?
regards
:thumbs:
I had a similar though more belt squeak noise and that would happen on cold start only, and generally below 2k rpm too.
This turned out to be the crank pulley, did it for about 6 months on and off until it fell off one day!!
Though because it was so random and sounded like a belt I had trouble trying to diagnose it. Though I fixed it with WD-40 at one point. Might be worth doing the tippex test anyway.
Toyotas comes on its own, if you want the other pulleys you
can order them individually or buy a custom set like Rob Mitchell
sells
Some of the billet blingy ones will come as a kit, you don't want
one of these full stop, their fine for the other pulleys but not the
crank pulley
I think I might order the Titan crank puller, thanks.
I'd just get a stock crank pulley Jazz, I can not remember 100% but the pulley has some sort of dampener which some non stock items don't have.
Not sure on the titan crank pulley but it doesn't look any different from a stock one!!
Thank Abz il check it out, if that's the case il order chris Wilson one :).
I've got a Titan crank pulley, is a 2 piece dampened job. Think they are just mroe heavy duty than the standard one. The one I have came off Johnny G's big twins car. Reason I bought is was just because it was cheaper than the Toyota one. :)
Does it work with stock parts? :)
