cooke Posted November 22, 2012 Share Posted November 22, 2012 Will an r154 gearbox fit an na mk4 if you just change the bellhousing Link to comment Share on other sites More sharing options...
Swampy442 Posted November 22, 2012 Share Posted November 22, 2012 Yes. But you'll also need the clutch, and prop shaft if I'm not mistaken. But save money and get a W58 Link to comment Share on other sites More sharing options...
cooke Posted November 22, 2012 Author Share Posted November 22, 2012 Ok thanks Link to comment Share on other sites More sharing options...
Darragh Posted November 22, 2012 Share Posted November 22, 2012 We're you from? You looking a gearbox? Or do you have one? Link to comment Share on other sites More sharing options...
cooke Posted November 22, 2012 Author Share Posted November 22, 2012 Northern ireland, i got sideskirts n spats for it recently and i just gotta get a do luck or ridox bumper and trd wing, then a full respray, i had just seen a really cheap r154 box and thought if it was easy enough to modify to the mk4 id get it and fit l8er Link to comment Share on other sites More sharing options...
listy Posted November 22, 2012 Share Posted November 22, 2012 Yes. But you'll also need the clutch, and prop shaft if I'm not mistaken. But save money and get a W58 This. W58's are cheaper, and an NA will never have the power to need more than that. Unless you are planning on going NA-T at some point, in which case, grab an R154, as its a much stronger box. Link to comment Share on other sites More sharing options...
Darragh Posted November 23, 2012 Share Posted November 23, 2012 That's probly my gearbox you seen for sale it's a good one, I'm only selling as I got a six speed conversion Link to comment Share on other sites More sharing options...
cooke Posted November 23, 2012 Author Share Posted November 23, 2012 Is it set up for a mk4? Link to comment Share on other sites More sharing options...
Darragh Posted November 23, 2012 Share Posted November 23, 2012 Nope just the gearbox itself with 7m bellhouseing, I have it on donedeal and gumtree, it doesn't take much to convert for a mkiv , do a quick search there is a great thread in here with everything you need to no for the conversion Link to comment Share on other sites More sharing options...
cooke Posted November 25, 2012 Author Share Posted November 25, 2012 Was the r154 in a 5speed 1988 Supra turbo or was it the w58 Link to comment Share on other sites More sharing options...
dr_jekyll Posted November 25, 2012 Share Posted November 25, 2012 you need a jz bellhousing, 1jz flywheel1 jz slave cylinder, 1jz pull type clutch, mk3 front prop section. chaser shifter exstension Link to comment Share on other sites More sharing options...
