Friends 97 Celica
cooke
Any know how to find out which ABS sensor is faulty on a 97 celica, i bridged the diagnostic port tc and e1 to find a fault code and the only thing that happens is the abs light stays on and the airbag light flashes steady, would the airbag light be the fault code light? If it is i understand that there is no fault and is probably dirty sensors
  • 2 weeks later...
As above.....
1. Remove the ABS short pin in the diagnostic connector.
2. Use a jumper wire over Tc and E1
Codes are:
11 - Open circuit in ABS solenoid relay circuit
12 - Short in ABS solenoid relay circuit
13 - Open circuit in ABS motor relay circuit
14 - Short circuit in ABS motor relay circuit
21 - Open or short in solenoid circuit from right front wheel
22 - " " " left front wheel
23 - " " " right rear wheel
24 - " " " left rear wheel
31 - Right front wheel speed sensor signal malfunction
32 - Left front " " " "
33 - Right rear " " " "
34 - Left rear " " " "
41 - Low battery positive voltage
51 - Pump motor is locked / Open in pump motor ground
ALWAYS ON - ECU malfunction / Abnormally high battery positive voltage
To clear codes:
1. With short pin removed and jumper wire in place across Tc and E1, turn ignition to ON position
2. Depress brake pedal 8 or more times within 3 seconds
3. Check that warning lamp shows normal code (blinks once every 0.5 seconds)
4. Remove jumper wire and replace short pin
