Water leak, where from?
Kaan W
I took a little trip to the bodyshop this morning and they said my car has a small oil leak with a puddle on the floor approx 4" in diameter after the car sitting there for a couple of days. After getting under the car its actually water but couldnt smell antifreeze in it. The puddle is directly below the gearbox sump.
Any ideas where this would be coming from?
Does any of the rain water get directed under the car around that place?
Could the block be cracked somehow?
Thanks
Edited by Kaan W (see edit history)
Could be a bugger of a heater pipe that goes right at the back of the engine bay (towards wind screen). Goes from left to right and is quite central just behind the cam covers. Had that leak on me once and took me an age to find.
Thats what I was thinking it could be. I just hope its not a cracked block or something.
Would the engine still run if its a cracked block? Cause it runs fine.
Yeah i'll check all round that area. The only reason I was thinking it could be a cracked block is because when I filled the car with coolant I poored it in the top rad hose while the engine was still hot. but then again when the thermostat opens that lets the cold straight into a hot engine. Its probably something simple...
I highly doubt it's a cracked block. It will more than likely be just an old warn out rubber pipe that is probably a pain to get to but cheap from Toyota (well it was a few years back). Don't stress it's just one of those things that's needs replacing rather than a major problem.
No it doesn't, the stat doesn't open till the water gets to whatever the stats
operating temp is, in the case of a mkiv a stock stat is i think 82 C
Pooring cold coolant into a hot rad or engine is a pretty daft thing
to do as all you do is end up with most of it coming back out at you.
I would say I poored about half a cup full in then realised I could crack the block so I poored boiling water from the kettle into it and it fixed my problem of not being able to bleed the coolant system by opening the stat and letting the water rush into the engine.
I shan't divert your thread but you really don't have to take any hoses off
or pour boiling water into it to make the stat work, you just need to run the engine
up to temp and if the stats working correctly it will open and you also shouldn't get
coolant or water leaping 2ft out the rad while its warming up.
Back to your leak, if it is coolant then the prime suspects are the
heater matrix inlet and outlet pipes.
Thats what I thought should happen but it didnt for the only reason I can think of is after the water shot out the engine there was no fluid touching the stat which meant it couldnt open even after the engine was warm. but as soon as I poored some hot water in the top hose it come into contact with the stat and opened it then the fluid level in the rad dropped and I topped it up from there.
I'll have a check around the heater matrix hoses for leaks.
Cheers.
No coolant in the engine is the reason the stat didn't open then, next time just fill it
up using the rad filler and guarantee it will work if the stat is working.
Good luck finding the leak and don't forget to get some antifreeze in the coolant
Yeah it was my fault for opening the lid when it was boiling hot.
Thank you and I will :)
check the two main hoses at the top at the back of the engine, that sit on top/front of the spark plug cover, i had this when i changed my plugs. i took the hoses off for better access, put it all back together, but FOTGOT to put one clip back on.
I reckon when the car is warm and upto temp, the coolant just started to pour out slightly. I only ever noticed it when the car was sat for a while
Thanks Geo :thumbs:
mine was sat for 12 months in a nice garage, when i decided to take it for mot i left it tickinbg over for a while and it developed a water leak, down the rear of the engine area, after it was inspected we noticed a small pin hole in the rear core glug.
Pain in the arse to remove and replace, but cheap a part.
Job done, new water/anti freeze and no worries for a while on that front
Yeah I suppose it could happen then. I'll have to check when I get my car back but im hoping it was from another car in there before mine or something spilt lol. I couldnt see water dripping from my car so with a bit of luck its not the car.
  • 2 months later...
clips are all back on your old car geo and car still leaks slightly from there, another job on my list lol
