Guest Wayne Rainsford Posted November 18, 2012 Share Posted November 18, 2012 Can any body please tell me if i have to lower engin on Supra 94 to take out 6 speed transmission. Hi to all my first time. Link to comment Share on other sites More sharing options...
Josh42 Posted November 18, 2012 Share Posted November 18, 2012 Undo the two engine mounts, jack up the front of the engine to lower the rear and it will allow you to remove it easier. Link to comment Share on other sites More sharing options...
absz Posted November 19, 2012 Share Posted November 19, 2012 No need to lower engine, Support the rear transmission mounting bracket using a jack and undo the mounting bolts then lower the jack down slighty that will give you all the room you need to gain access to the top bell housing bolts. Link to comment Share on other sites More sharing options...
