FOSTA Posted November 16, 2012 Share Posted November 16, 2012 Ok I'm wanting to get my compression right on this new engine I'm building, So I'm trying to Work out what commpression to go for. A member on here made 500bhp at 1bar of boost at a CR of around 9.03.1 Another member made 600bhp at 1.5bar of boost but he is unsure of his CR he knows he has TT pistons in his NA but is not a 100% sure if he also has the thicker TT Headgasket. (Both are NA-T) So if a TT has a CR of 8.5.1 what sort of boost will it need to hit around 600bhp mark? ( I know there is a lot that affects bhp like supports mods, cams etc) But I'm just after a rough outline. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Kaan W Posted November 16, 2012 Share Posted November 16, 2012 Im on 8.5:1 CR and make 600bhp @ 1.6bar Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 16, 2012 Author Share Posted November 16, 2012 Thanks mate Any others ? Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted November 16, 2012 Share Posted November 16, 2012 who is this fellow who makes 600 at 1.5 bar? sounds like abit of a handsome chap Quote Link to comment Share on other sites More sharing options...
Chris Bailey Posted November 16, 2012 Share Posted November 16, 2012 who is this fellow who makes 600 at 1.5 bar? sounds like abit of a handsome chap Your so happy your car makes 600bhp I'd like to think dad's is are not that far behind! Quote Link to comment Share on other sites More sharing options...
Kaan W Posted November 16, 2012 Share Posted November 16, 2012 who is this fellow who makes 600 at 1.5 bar? sounds like abit of a handsome chap I said 1.6bar Quote Link to comment Share on other sites More sharing options...
tkddav3 Posted November 16, 2012 Share Posted November 16, 2012 Your so happy your car makes 600bhp I'd like to think dad's is are not that far behind! mibee i am I said 1.6bar if i were on about you kaan i would of said the bloke a 1.6bar who looks like a garden knome Quote Link to comment Share on other sites More sharing options...
Nic Posted November 17, 2012 Share Posted November 17, 2012 (edited) What turbo is being used? It's all about airflow not boost pressure, eg. a 72mm turbo at 1.6bar will produce a lot more power than a 60mm turbo at the same boost pressure. Edited November 17, 2012 by Nic (see edit history) Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 17, 2012 Author Share Posted November 17, 2012 Ok then, so if I was to have a CR of around 9.03.1. What would be the best turbo to get me to around 600bhp? I am wanting one to get me there using the lowest boost I can. (Obviously using the correct supported mods along side) Quote Link to comment Share on other sites More sharing options...
Noz Posted November 17, 2012 Share Posted November 17, 2012 Any turbo that can supply enough air can supply 600bhp. its just how the power is delivered mate. You want to max out your turbo for best results for any given power, but obviously you need room for more power. In an idle world each turbo would run 90% for every setup so you can fast hard spool and dont spool a turbo that feeds the wastegate with pressure. I would try it on your current turbo, and see how far you can get. Higher the compression the less boost your need. Dont forget that it's not boost that denotes your power, its air volume which is turbo capacity and pressure of that volume area. Quote Link to comment Share on other sites More sharing options...
Nic Posted November 17, 2012 Share Posted November 17, 2012 What would be the best turbo to get me to around 600bhp? Best? A billet 62-67mm, double ball bearing T4 turbo, I'd go with a Garrett GTX3582R running around 1.5bar or if you want something a bit cheaper a T-04Z. Quote Link to comment Share on other sites More sharing options...
FOSTA Posted November 17, 2012 Author Share Posted November 17, 2012 Best? A billet 62-67mm, double ball bearing T4 turbo, I'd go with a Garrett GTX3582R running around 1.5bar or if you want something a bit cheaper a T-04Z. Ok mate, I'm not sure if you can answer this one but would it be safe to run 1.5bar of boost on a compression ratio of around 9.03.1? With a CR of 10.1 (stock NA) your limits are 9psi /0.6bar Now I think I read somewhere that at 9.03.1 your limitations are around 17psi / 1.1bar? But I'm not a 100% on this. Quote Link to comment Share on other sites More sharing options...
