SupraP-Z Posted November 16, 2012 Share Posted November 16, 2012 Hey all, after i put my foot down, i get two warning lights come up (same lights that come on when your handbrake is on) mostly it happens on hard braking, or after ive let off on hard acceleration. Car is an N/A. I did think fluids straight away...but brake fluid looks fine, clutch fluid looks fine...power steering fluid is a tad low, coolant is fine, windscreen washer fluid needs topping up...oil level seems perfect, anything else it could be? Link to comment Share on other sites More sharing options...
Nic Posted November 16, 2012 Share Posted November 16, 2012 Brake fluid low, the sensor is very sensitive, top it a bit more. Whilst you're at it check the brake pads/discs for wear and brake lines/calipers for leaks. Link to comment Share on other sites More sharing options...
James Posted November 16, 2012 Share Posted November 16, 2012 Double check the brake fluid - the sensor is extremely sensitive. Link to comment Share on other sites More sharing options...
SupraP-Z Posted November 16, 2012 Author Share Posted November 16, 2012 Cheers fellas, will double check this asap Link to comment Share on other sites More sharing options...
Dnk Posted November 16, 2012 Share Posted November 16, 2012 I'd go one further and do a brake fluid change unless you know its been done in the last couple of years. Transforms your brakes if you have old stuff in there that's full of moisture Link to comment Share on other sites More sharing options...
SupraP-Z Posted November 16, 2012 Author Share Posted November 16, 2012 Im going to be doing a full fluid change this service, try and drain and replace as many as i can. Got to have a look at the service/repair manuals on here, anyone wanna help? Link to comment Share on other sites More sharing options...
