Big water pipe- runs around engine
Rob_Mitchell
TBH Roberto, fitting twins with the engine in the car would be the biggest arse of them all! So your best bet is to remove it and stick it on a stand. This will also give you the opportunity to clean all the nooks and crannies you can't get too, which we all know you love. :)
Ohh and btw, can I have the blank from your second oil feed plz? I'll need it for my car. :) You can post it to me along with my rad clamps that i'll never see again! :D
Edited by TheTurtleshead (see edit history)
Ohh and btw, can I have the blank from your second oil feed plz? I'll need it for my car. :) You can post it to me along with my rad clamp!
Yeah i guess thats what ill do then, no huge drama i guess, just bit more planning and time.
Yeah those bloody nooks and crannies!!
The pipe(s) an almost complete 'U' round the back of the block and down the sides (not quite as far towards the front on the intake side but still a sizable and awkward piece). Unless you botched the rear section by cutting and using hose I can't see how you'd get it out without at least one side (intake must be easier?) being removed.................whats up with it?
Needs to be changed for new turbo kit really! little bit gutted :D as i know its not a easy or quick job taking the engine/box out. Ill try and have a read about but it dont look good, so instead of finding a short cut ill be better off just getting it done
