scott87 Posted November 14, 2012 Share Posted November 14, 2012 Im looking to see if there is anyone in the midlands area that would be willing to help me out with a days mechanical work. I can come to you with tools or vice versa although my garage is without electricity which could cause a problem. I am basically in need of some work done and cant afford both jobs to be done at a garage, one of which is the clutch which im not confident changing on my drive anyway. The second and work im asking for help with (as ive never done it on a Supra), is changing the water pump and i guess the timing belt whilst im there, Im assuming its around 3-4 hours work but correct me if im wrong. So if there is a lovely person out there willing to help i can ply with beers for the trouble, once the work is done else it could go terribly wrong I live in Coventry so can travel. Link to comment Share on other sites More sharing options...
Swampy442 Posted November 14, 2012 Share Posted November 14, 2012 Ive got no probs helping you with the water pump and belt, have a genuine Toyota crank pulley locking tool as well, problem is Im in Lincoln which is a bit of a trek.. Link to comment Share on other sites More sharing options...
Dnk Posted November 14, 2012 Share Posted November 14, 2012 I would assist but no longer have my workshop. I use a very good local village garage if its any use and they don't charge crazy rates, i could enquire on cost for you, they do most jobs on my supra Link to comment Share on other sites More sharing options...
little num Posted November 14, 2012 Share Posted November 14, 2012 I have a workshop in bromsgrove with airtools and all the tools you could ever need, also is the car a TT or NA, pm me your number and ill call you to see what you want to do. Link to comment Share on other sites More sharing options...
scott87 Posted November 18, 2012 Author Share Posted November 18, 2012 Cheers for the replies :-) I know a good garage that is cheap, but i'd like to do the work myself (with help) Lincoln is quite far, but not a difficult journey. Link to comment Share on other sites More sharing options...
scott87 Posted November 20, 2012 Author Share Posted November 20, 2012 Ok ive now been told that i shouldn't worry about my water pump having covered 100,000miles and should just change it when my timing belt needs doing. So this now means the job i need doing is changing the rocker gasket and bleeding the brakes. Again looking for some help as i dont have a garage the Supra will fit in, nor does it have electricity. So either way looking for help with much simpler job this time (Unless someone comes along screaming that 100k is far too many miles on the pump) Link to comment Share on other sites More sharing options...
